Mendel90
Release status: Experimental
Description | A Mendel with flat sheets at 90 degree angles
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Mendel90 is a design by Nophead that replaces many of the threaded rods and printed parts of the Prusa Mendel with flat sheets, either MDF or Acrylic. This simplifies construction, stiffens the frame, and always keeps the axes at 90 degree angles, hence the name.
Advantages
Compared to the Prusa Mendel, which it is based on:
- Fully parametric across build area, motor size, rod size, and sheet material. You can customize all the parts and increase the build area, and the OpenSCAD model will reflect it
- Stiffer, especially in the X Direction, so it can go much faster without vibration
- Much less calibration and jigging required; if your holes are in the right places, your rods will be parallel. If the buttresses are square, your printer will be square.
- Can be drilled with a paper template to make sure all holes are perfect
- Sheets are usually straighter and flatter than rods, as they are thicker and much wider
- Everything is mounted on one of two planes, so it's all flat
- Frame is held together throughout the machine, instead of just at the corners, so much less warping
- Fewer vitamins
- Open frame design, allowing it to be worked on easily and mostly disassembled without falling apart
- Z axis motors are at the bottom, so that the couplings don't need to support the weight of the X axis
- The Z couplings can be smaller, and therefore the Z smooth rods closer to the threaded rods, increasing stiffness
- The center of balance is lower, making it more stable
- Less printed parts, so it can be printed easier and faster
- Parts are ribbed to maintain strength and decrease print time
- Ribbon cables are used to prevent cable tangling and friction
- Rectangular, so it can be shipped and put in Heated Build Chambers easier.
- Uses LM8UU bearings
- Uses 10 instead of 12, so only one package is needed
- Fewer bearings make it less susceptible to problems with overconstraint
- Heavier and stiffer construction makes it more resistant to decalibration due to transportation.
- Less need for adjustment
Disadvantages
- If you drill a hole wrong, it is much harder to fix than to adjust a nut on the Prusa Mendel
- Less room for adjustment-only a few mm
- MDF expands with heat, though less than steel, and also with moisture. Acrylic cracks. MDF could be sealed to slow response to changes in humidity.
- OpenSCAD files have not been released as of March 5, 2012, ETA March 11.
- More volume of vitamins-sheets are larger than rods
- Probably heavier and harder to ship
- More types of screws
- Louder because sheets act as soundboards
- Fewer bearings might make it less accurate
- Ribbon cables cause electrical interference, false positives in the endstops and inaccurate thermistor readings. With sensible firmware this isn't an issue.
- A Possible solution would be to have the motor signals separated from the signal lines by a pair of grounded wires connected in a loop. This will be tested soon.
FAQ
- Why so many types of screws?
- Motors, electronics and power supplies need M3 screws. Bearings and fans need M4. Some screws need to be the right length, e.g. into blind motor holes and the base. Others could be longer than needed but it would look ugly if the frame screws went right through the panels and it is tedious screwing long screws through Nyloc nuts.
- Pan heads are a bit cheaper and faster to put in when there is something to push against, e.g. the frame. When there isn't cap head screws are preferable because they don't need any force, so don't push the captive nuts out or stress the assembly they are screwed into. Pan head can be substituted if desired but are more fiddly to fit. Cap head can be substituted for pan head if preferred but the frame is a little easier to assemble with a screw driver.
- Hex head screws are needed where there is no access for a screw driver or an Allen key, but would be tedious anywhere else.
Development
The Mendel90 is being designed solely by Nophead, and he has shared his design through his blog and Thingiverse. He has made one prototype, out of 12mm MDF and 10mm rods. It has a build area slightly larger than the Mendel (214x214x150), and he is working on another prototype of 6 and 10mm acrylic and 8mm rods, with the same build area as a Mendel. This design is the one that all the files released on Thingiverse belong to. Before Nophead released the STL files through Thingiverse, Stevetronics worked on making his own version from the pictures on Nophead's blog, first in Solidworks and then in OpenSCAD. AdrianKelly is working on making a wooden Repstrap based on the Mendel90.
Nophead says he will put his OpenSCAD files on Github, but they are not up yet.
There are STLs linked below for a 8mm rod version with NEMA17 motors, T5 belts and an acrylic frame. They are copied directly from Thingiverse.
Bill of Materials
Printed Parts
STLs are links to Thingiverse, how do I upload them to the wiki instead?
Required
Quantity | Description | File | Diagram |
1 | Bar Clamps | stl | |
10 | Fixing Blocks | stl | |
2 | Pulley | stl | |
1 | X Motor Bracket | stl | |
1 | X Idler | stl | |
1 | X Carriage | stl | |
1 | Y Motor Bracket | stl | |
1 | Y Idler | stl | |
1 | Y Bearing Mounts | stl | |
1 | Y Belt Anchors | stl | |
1 | Z Motor Bracket | stl | |
4 | Z Coupling | stl |
Modified Wade's Geared Extruder
1 | Extruder Body | stl | pic |
1 | Extruder Idler | stl | pic |
1 | Small Gear | stl | pic |
1 | Large Gear | stl | pic |
1 | Gear Spacer | stl | pic |
1 | Cable Mount | stl | pic |
Optional
1 | Fan Guard-If you have a fan | stl | |
1 | Cable Clips | stl | |
2 | Z Pointer | stl |
Non-Printed Parts ("vitamins")
All measurements are in millimeters. Should this be a table instead?
1 Sheet 468 x 432 x 10 2 Sheet 170 x 324 x 6 1 Sheet 224 x 224 x 6 1 Sheet 468 x 324 x 6 4 19mm bulldog clip 3 624 Ball bearing 4 x 13 x 5, 1 for X idler, 2 for Y idler 3 608 Ball bearing 8 x 22 x 7, for extruder 22 M3 cap screw x 10 22 M3 cap screw x 16 17 M3 cap screw x 20 4 M3 cap screw x 25 2 M3 cap screw x 30 2 M3 cap screw x 45 4 M4 cap screw x 20 2 M4 cap screw x 40 1 9 way D plug 1 9 way D socket 3 M3 grub screw x 6 1 borosilicate (Pyrex) glass sheet 214 x 202 x 2 5 M3 hex screw x 16 2 M4 hex screw x 20 2 M4 hex screw x 50 1 M8 hex screw x 60 10 LM8UU 5 NEMA17x47.5 1 PCB bed 1 polypropylene strip 373mm x 17mm x 0.5mm 1 polypropylene strip 320mm x 27mm x 0.5mm 1 polypropylene strip 275mm x 29mm x 0.5mm 38 M4 pan screw x 12 24 M4 pan screw x 16 1 Smooth Rod 8 x 22, for extruder idler 3 Smooth Rod 8 x 275, 2 for Z axis, 1 for Y 2 Smooth Rod 8 x 382, for X axis 1 Rod 8 x 428, for Y axis 2 Threaded Rod 8 x 211 2 Tubing OD 7 ID 5 x 16 12 No2 pan wood screw x 13 6 ziptie 87 1 belt T5x6x674 1 belt T5x6x861 4 hex pillar M3x20 3 microswitch 6 nut M3 2 nut M4 3 nut M8 45 nyloc nut M3 6 nyloc nut M4 2 rubber washer M3 x 9.7 x 1.5 1 spring 12 x 0.75 x 10 2 spring 7 x 1 x 10 18 star washer M3 x 7 x 0.5 53 star washer M4 x 9 x 0.9 12 washer M2.5 x 5 x 0.5 79 washer M3 x 7 x 0.5 78 washer M4 x 9 x 0.9 4 washer M5 x 20 x 1.4 1 washer M8 x 16 x 1.5 2 wingnut M4
