Megatronics
Revision as of 12:16, 6 December 2015 by Phd0 (talk | contribs) (How to get it)
Megatronics
Release status: Working
Single board solution, Remix of Arduino mega and RAMPS
Summary
After using RAMPS for a long time I am still quite fond of it. There are some aspects of the board however that make it unusable for future electronics, which should be reliable and cheap. Also the wiring can we a bit fiddly. I have combined the Arduino MEGA and RAMPS boards into a single board solution. Only the stepper drivers are still modules for easy replacement.
Megatronics is based on many famous open-source products including: Arduino Mega 2560, RAMPS, SD Ramps. Therefor this product is an already proven design. It combines all major features of these board into a single board solution for more reliable 3D-printing.
Megatronics has a powerful Atmega2560 processor with 256 kB memory, running at 16Mhz. The board can be connected to a PC using a normal USB cable. It will register as FTDI FT232R device. The board is compatible with the Arduino Mega 2560 and will therefor be easily programmed from the Arduino IDE.
Benefits
  1. Single board solution, +/- 12x12cm
  2. Powerful Atmega 2560 on board
  3. A lot of features standard on board, including SD card and thermocouple support
  4. Compatible with the standard Arduino software
  5. Cheaper solution, because it's one board
Specifications
   Microcontroller: Atmega2560-16AU
   Operating Voltage Electronics:5V
   Operating Voltage High:12-24V (15A heated bed, 7A electronics)
   DC Current per I/O Pin:40mA
   Clock Speed:16Mhz
Features
   Improved thermo couple support.
   Second thermo couple supported
   Support for 6 stepper drivers
   SMD fuses and MOSFETs
   Extra MOSFET, making 4 regular MOSFETs and one for heated bed.
   Support for the new DRV8825 Pololu stepper drivers
   The board can be powered from 12V1 (12V MAX), by setting a jumper
   The LCD contrast can be adjusted with a trimpot
   12V1 has a diode to protect against reverse polarization
   The 5V line is protected by a 500mA resettable fuse
   A piezo is included to allow the printer to give feedback with sound
   Each stepper driver slot has a breakout to connect external stepper drivers to the board.
   Four layer high quality PCB board
How to get it
More information coming soon
