Mattroberts' Huxley Paste Extruder
Revision as of 15:16, 3 August 2012 by Mattroberts (talk | contribs) (add BOM)
Everything here is new, but is influenced by RichRap's Universal Paste Extruder. This design will work on a RepRapPro Huxley.
What you need
  • 1x each of the RP components
  • 1x NEMA12 Motor (I used a SY28STH32-0674B from zapp automation)
  • 1x XL timing belt
  • 5ml syringe
  • 5x 624 bearings
  • 1x M4x36mm studding (a little longer will not cause problems)
  • 1x M4x58mm studding (a little longer will not cause problems)
  • 2x M4 nyloc nuts (M4 nuts and super glue will work)
  • 7x M4 nuts
  • 3x M4 washers
  • 2x M3x8mm bolts (longer will cause problems, but can be cut from 12mm bolts)
  • 2x M3x12mm bolts (longer will not cause problems)
  • 2x M3x25mm bolts
  • 6x M3 nuts
  • 4x M2.5x6mm screws
How to assemble
MR Huxley Paste 3413.jpg MR Huxley Paste 3414.jpg MR Huxley Paste 3415.jpg MR Huxley Paste 3416.jpg MR Huxley Paste 3417.jpg MR Huxley Paste 3418.jpg MR Huxley Paste 3419.jpg MR Huxley Paste 3420.jpg MR Huxley Paste 3421.jpg MR Huxley Paste 3423.jpg MR Huxley Paste 3425.jpg MR Huxley Paste 3426.jpg MR Huxley Paste 3430.jpg
