MakiBox
Revision as of 07:45, 16 July 2013 by JustMaD (talk | contribs) (Specialities)
MakiBox
Full case 3d printer
Introduction
It’s the first 3D printer designed from the ground up to be simple, completely self-contained, reliable and most important of all, affordable!
The MakiBox A6 utilizes a desktop-friendly, partially enclosed design, within a space barely bigger than a sheet of A4 paper. The filament fits on a spool-holder at the back of the MakiBox, keeping things neat and compact.
The MakiBox is designed to be more simple and reliable than any other in this class. Instead of using complicated belts and pulleys, it uses simple drive screws, reducing the number of parts, the cost, and the assembly and maintenance time. The most difficult parts will come pre-assembled, such as the extrusion head or the drive shaft coupling so that the kit assembly is no more difficult than IKEA furniture. Build time is about 2-3 hours.
Initial development started with a successful crowdfunding campaign at the end of 2011 and since then ran through some beta stages with increasing performance and quality. Mass production of the printer is just about to start (as of July 16th 2013) and pre-orders should start shipping within the month.
Specifications
  • Models: LT (without heated bed), HT Acrylic/Stainless steel (with heated bed)
  • Printed Parts: None on production model
  • Non-Printed Parts: Laser cut acrylic or stainless steel panels. POM (generic Delrin) injection molded brackets and gears.
  • Electronics: Printrboard Rev B
  • Material Cost: ???
  • Cost: USD 200 (LT), 300 (HT Acrylic) or 350 (HT Stainless Steel) + shipping. Early buyers got $50 flat shipping fee. May be additional local taxes or fees. (Partially assembled.)
  • Outside Dimensions: 290mm wide x 235mm deep x 235mm tall (without filament loaded)
  • Printing Size: 110mm x 150mm x 90mm
  • Precision: 0.04mm (position/printing)
  • Speed: 40-60mm/s (position/printing)
  • Head: XY
  • Bed: Z
Specialities
  • Full acrylic or optional stainless steel casing.
  • Mass-produced injection-molded precision parts
  • Optional pellet to filament drive (named "Ramen Extruder") creating 1.75mm filament (still in development)
  • Trapezoidal drive shafts, no pulleys
  • Makibox HT, USD 300, has a heated printbed and can print in ABS, PLA, or any similar material
  • Makibox LT, USD 200, has a non-heated printbed and can print in PLA only
Development Process
MakiBox started to create a self-contained pellet driven 3d printer, but while the development the pellet driver "MakiBox Ramen" and the actual 3d printer "MakiBox A6" were disconnected, the pellet driver does not feed the printer extruder direct due discovered difficulties:
The problem is that you do need something to separately pull the filament from the (pellet) extruder and push it into the printer (extruder), if you are doing a feed tube and not direct printing. The reason for this is that the flow will get stuck extremely easily from the extruder with small amounts of back pressure. There is always somewhere in the feed that the material is molten enough to mushroom against the back pressure. -- (Jonathan Budford, 2012/12/24)
So the pellet to filament ("MakiBox Ramen") is within the same case but is now treated as an add-on and creates filament on a spool and then once rolled, used for the actual printer "MakiBox A6".
Links
