MaKrPanel
Description | Release Version 1.0
License | unknown
Author | |
Contributors | |
Based-on | [[]]
Categories | |
CAD Models | |
External Link |
Introduction
The MaKrPanel features a blue graphical LCD with white backlight, a microSD, switch encoder and a buzzer. It can be fitted to most existing 3D printer controller boards.
This panel adds a convenient user interface to the printer hardware to allow for stand-alone printing from a micro-SD card. The PCB matches the mounting holes on the MaKr Melzi board. Using the included screws and spacers the panel and board can be assembled to one compact unit without big cable mess.
The display contrast is fully software-controllable, no need for a contrast adjustment poti. The backlight can be switched on and off using any digital output signal. If connected to a PWM capable output, dimming is possible.
Electrical connection
The LCD is connected to the CPU using a unidirectional SPI connection. In addition to the usual SPI signals /Reset, SCLK and MOSI the LCD needs two additional output signals for LCD_A0 (or LCD_RS) and LCD_CS.
The SPI signals are connected using the regular 6-pin Atmel ISP connector and the additional two lines for LCD_A0 and LCD_CS are connected using an additional 10-pin connector. Both pin header, the 6-pin and the 10-pin, are arranged in a way that they can be contacted using a single 20-pin connector with four unused spare pins in between.
The detailed pinout is as follows (seen from above, to the pins, with the empty space in between the two connectors):
/LCD_CS 1 2 LCD_A0 ENC_SW 3 4 Beep ENC_A 5 6 Backlight ENC_B 7 8 SD-SS Vcc +5V 9 10 GND . . . . MISO 1 2 Vcc +5V SCLK 3 4 MOSI /Reset 5 6 GND
Software support
The Marlin firmware already includes support for ST7565-compatible graphical LCDs.
Programming tutorial for a similar module: [1]. Please note: The adafruit display used in this tutorial has a different page mapping. For use with our module you need to modify the pagemap by editing this line in the file c/stlcd.c:
int pagemap[] = { 7, 6, 5, 4, 3, 2, 1, 0 };
An Arduino library for the DOGM128, another software compatible ST7565R-based display: [2]
Technical Details
- LCD resolution: 128 x 64 pixel
- Display: white/blue (blue background, active pixels white), black metal frame
- Visible area of the LCD: 55 x 27.48 mm²
- Pixel size 0.39x0.39mm²; Total pixel pitch 0.43mm
- LCD controller: ST7565R, SPI protocol
- Encoder switch with press button, 24 clicks per round
- Buzzer
- MicroSD slot
- 5V/70mA at full backlight brightness plus up to 100mA for the microSD card
- Connects to the 6-pin Atmel ISP connector and another 8 digital lines
- Total size: 50 x 98 mm²
