List of Firmware
Revision as of 20:41, 16 December 2011 by Bubbapizza (talk | contribs) (convert to templates)
This page is the authoritative list of active firmwares.
For a list of out-of-date firmwares, see List of Abandoned and Deprecated Firmware:
FIRMWARE INFO
Details Description
Author(s) : Buzz and others
Status : active as of Sept 28, 2011
The granddaddy of all firmwares. It appears to be the original G-code interpreter. Forked from Generation2. The reason it's called FiveD is because it controls 5 dimensions: X, Y, Z, Feedrate, and Extrusion rate.
Features
  • stepper extruder
  • extruder speed control
  • movement speed control
  • RepRap-style acceleration
  • thermocouples
  • heated build platforms
Compatible Electronics
How to download
The firmware is now hosted on Github. To check it out from github, run:
git clone https://github.com/reprap/firmware.git
The firmware is in the FiveD_GCode Directory
Documentation & Misc. Notes
Documentation is over at Microcontroller firmware installation
Preconfigured sources for Gen7 hardware are on the Gen7_Board_1.2 page.
FIRMWARE INFO
Details Description
Author(s) : Kliment, caru, tonok, tesla893
Status : Active as of July 5, 2011
forked from Klimentkip. Seems to be a popular firmware
Features
  • SD card reader
  • stepper extruder
  • constant or exponential acceleration
How to download
Can download like this:
git clone https://github.com/kliment/Sprinter
Only documentation seems to be over at Sprinter
  • Possibly called Carukip too
  • Supposedly aka Tesla but I can't find any references in the wiki to that
  • thermocouples are experimental
FIRMWARE INFO
Details Description
Author(s) : {{{author}}}
Status : Active as of November 2011
This was a complete rewrite of the FiveD firmware to optimize it for Arduino's wimpy 8-bit CPU. Previously known as "FiveD on Arduino" ( which was confusing it easily with "FiveD" which is different).
Features
  • Has better performance due to
  • written in C instead of C++
  • only uses integer math
  • minimizes long math interruptions
  • stepper extruder
  • start-stop ramping
  • thermocouples
  • Support for spindles, CNC-milling
  • Unlimited number of extruders
How to download
git clone https://github.com/triffid/Teacup_Firmware.git
Documentation and more information is over at github and on the wiki under Teacup Firmware.
Supposedly there are the instructions on the Gen7 electronics page on how to get Teacup installed but I can't find them. A link would be helpful here.
  • this firmware was ported to ARM Cortex-M3 for the HBox_RepRap_Electronics.
  • DC motor control is present but untested
  • contains a constant acceleration implementation based on this article
FIRMWARE INFO
Details Description
Author(s) : ScribbleJ
Status : active as of Aug 8, 2011
A featureful modern Reprap firmware.
Features
  • High-speed gcode pipeline. No intra-move delay.
  • LCD/Keypad control panel, Hostless printing
  • Acceleration
  • Volumetric/5D
  • SD Card
  • FULL RUNTIME CONFIG.
  • See the sjfw page for more information.
{{{electronics}}}
How to download
Download from GitHub by running
git clone https://github.com/ScribbleJ/sjfw.git
{{{documentation}}}
FIRMWARE INFO
Details Description
Status : Public Beta 1 of v1.0.0
forked from Sprinter and Grbl.
Features
  • Look ahead (Keep the speed high when possible. High cornering speed)
  • High steprate
  • Interrupt based temperature protection
  • Interrupt based movement with real linear acceleration
  • preliminary support for Matthew Roberts advance algorithm For more info see: http://reprap.org/pipermail/reprap-dev/2011-May/003323.html
  • Full endstop support
  • SD Card support
  • SD Card folders (works in pronterface)
  • LCD support (ideally 20x4)
  • LCD menu system for autonomous SD card printing, controlled by an click-encoder.
  • EEPROM storage of e.g. max-velocity, max-acceleration, and similar variables
  • many small but handy things originating from bkubicek's fork.
  • Arc support
  • Temperature oversampling
  • Dynamic Temperature setpointing aka "AutoTemp"
  • Support for QTMarlin, a very beta GUI for PID-tuning and velocity-acceleration testing.
  • Endstop trigger reporting to the host software.
  • Updated sdcardlib
  • Heater power reporting. Useful for PID monitoring.
How to download
You can download tagged versions on github All branches, most current is Marlin_v1 are on Github
The included readme.md Marlin
FIRMWARE INFO
Details Description
Author(s) : Who knows
Status : active as of Nov 9, 2011
The v2 makerbot firmware was a rewrite of the old Gen3 firmware to be a little more robust. The latest version appears to be v3.2.
Features
How to download
Download from Makerbot's github repo using the commands
git clone https://github.com/makerbot/G3Firmware.git
The v3 firmware is where all active development takes place. See the Makerbot wiki for details on how to build and install the code.
FIRMWARE INFO
Details Description
Author(s) : Simen Svale Skogsrud
Status : active up to Feb 2011
Grbl is a no-compromise, high performance, low cost alternative to parallel-port-based motion control for CNC milling. Does not control extruders.
Features
  • run on a vanilla Arduino (Duemillanove/Uno) as long as it sports an Atmega 328
  • nice simple controller for CNC milling
  • written in tidy, modular C
  • does not require parallel port
  • able to maintain more than 30kHz step rate and delivers a clean, jitter free stream of control pulses.
  • full acceleration-management with look ahead planner
How to download
Downloadable from github by running:
git clone [email protected]:simen/grbl.git
Documentation is at http://dank.bengler.no/-/page/show/5471_gettinggrbl
From the website:
We have limited g-code-support by design. Grbl support all the common operations encountered in output from CAM-tools, but leave human g-coders frustrated. No variables, no tool offsets, no functions, no arithmetic and no control structures. Just the basic machine operations. We have yet to find a CAM-generated file that failed to run, though.
  • No gui, all interaction is through command line
