LabRap/en
Revision as of 07:51, 1 March 2016 by Hanlest (talk | contribs)
Please do not add to this page. (It is slightly overcrowded as it is.)
This Page Contains multiple RepRap development projects and should be split up. Each individual project/design/improvement should have its own development page within an encompassing category.
Introduction
Designed and built by the group 'Reprap Chile',
Made of the prototype
Prototipo (1).jpg Prototipo (2).jpg Prototipo (3).jpg Prototipo (4).jpg Prototipo (5).jpg Prototipo (6).jpg Prototipo (7).jpg Prototipo (8).jpg Prototipo (9).jpg Prototipo (10).jpg Prototipo (12).jpg
Prototipo (13).jpg Prototipo (17).jpg Prototipo (18).jpg Prototipo (19).jpg Prototipo (21).jpg Prototipo (22).jpg Prototipo (23).jpg Prototipo (24).jpg
Improvements included
  • The upper brackets of the shaft flat rods joined in one piece Z
  • Threaded rods by screws were changed to improve print quality in the Z axis
  • The arm holding the filament to withstand rolls of 200mm in diameter and 100mm wide changes.
  • Frame is modified to allow the use of a single roll of filament or two as needed.
  • Two small parts for truck extruder that lets you choose between a single or double one extruder added.
  • It extends a few millimeters bracket Y-axis motor to prevent this abutting the anchor nut.
  • A belt tensioner is added to the Y axis
  • Perforations are added to mount vertically and horizontally electronics.
  • Available space is left for mounting the case then acrylic.
Proteins
The LabRap printer does not require printed pieces, unless a direct extruder MK8 is used.
Adaptador para extrusor directo
Description Link Image
Adapter for direct extruder http://www.thingiverse.com/thing:835475 Mk8 mount preview featured.jpg
Vitamins
Parts Quantity Description Image
Allen screws M3x12 90 It allows joining aluminum parts M3x10inox-500x500.jpg Tornillos-Din-7380-inox-500x500.jpg
Allen nuts M3 100 It allows joining aluminum parts Tuerca cuadrada.jpg Tuerca exagonal.jpeg
Allen screws M3x8 12 It lets ride engines M3x10inox-500x500.jpg Tornillos-Din-7380-inox-500x500.jpg
Allen screws M3x25 3 It allows joining aluminum parts M3x10inox-500x500.jpg Tornillos-Din-7380-inox-500x500.jpg
Allen screws M3x20 14 It allows joining aluminum parts M3x10inox-500x500.jpg Tornillos-Din-7380-inox-500x500.jpg
Allen screws M8x25 2 It allows mounting of bearings M3x10inox-500x500.jpg Tornillos-Din-7380-inox-500x500.jpg
Allen nuts M8 2 It allows mounting of bearings Tuerca cuadrada.jpg Tuerca exagonal.jpeg
Allen screws M4x8 3 It allows mounting the power supply M3x10inox-500x500.jpg Tornillos-Din-7380-inox-500x500.jpg
Black heat shrink tubing of Ø 2.5 x 500mm 2 To protect cable joints Tubo termoretráctil.png
Recogecables link chain stitch Igus (optional) 52 para proteger y guiar los cables del eje X y el eje Y Eslabón cadeneta recogecables Igus.png
Black binder Clip (35x10mm) 4 To attach the glass to the hot bed Binder Clip Negro (35x10mm).png
Tools
Name Quantity Description Image
Ceramic trimmer screwdriver 1 Ceramic trimmer screwdriver for adjusting the current pololus. Destornillador trimmer.PNG
Acupuncture needle 0.32 x 100mm 2 Necessary for the maintenance of hotend, it prevents jams. Aguja acupuntura.png
Printed fixed key 10 (M6) - 13 (M8) - 17 (M10) 1 Printed spanner nuts for mounting M6, M8 and M10. Llave fija impresa.png
Soldering iron and tin 1 Welding cables, motors and Endstop Soldador y estaño.png
Electronics
Parts Quantity Unit price Total price Image
Mecanical parts
Smooth bars
They are necessary 6x8mm steel bars of the following sizes:
  • 2x Ø8x395 mm for X axis.
  • 2x Ø8x341 mm for Y axis.
  • 2x Ø8x320 mm for Z axis.
Laser cut parts
  • 58 pieces cut into 3mm thick aluminum.
DWG file with the blueprint cut parts.
File:LapRap Plano corte.zip LapRap_Plano_corte Autocad 2010-2013
Firmware Marlin
RepRap Marlin
Firmware con los parámetros probados. File:LabRap v1.0-200mm-Marlin-Release.zip
Extruder
The LabRap model is designed to using an bowden MK8 extruder and E3D V6 hotend
It is also possible to use an MK8 extruder with a corresponding adapter Download adapter File:Mk8 Extruder mount for Prusa i3 Rework.zip Mirror
Other model for adapter: Download alternative adapter (Sintron)
Download alternative adapter 2
Other extruders
MK8 extruder + V6 HotEnd
MK8+V6 extruder (hanlest)
Kuro's compact bowden geared extruder
Kuro's compact extruder
Kuro's Compact Bowden Geared Extruder.jpeg Kuro Compact Bowden Geared Extruder 2.jpeg Kuro Compact Bowden Geared Extruder 3.jpeg
Compact bowden extruder
Compact Bowden Extruder 1.jpeg Compact Bowden Extruder 2.jpeg Compact Bowden Extruder 3.jpeg
Prusa i3 direct drive bowden extruder
Direct drive bowden extruder
Geared extruder v.3
Extrusor Geared V3
Videos
<videoflash>mb4Pr4k5BpU</videoflash> <videoflash>MXxVImFkHi4</videoflash>
Optional upgrades
608ZZ bearing cover :
Allows the pulley is always kept at the center of the bearing. bearing cover for 608ZZ
GT2 Pulley for 608ZZ 1.jpg GT2 Pulley for 608ZZ blueprint.jpg GT2 Pulley for 608ZZ 2.jpg GT2 Pulley for 608ZZ 3.jpg
System for x axis endstop
This piece is to improve Endstop Z axis, it is composed of a knob and a spring. EndStop Z axis
Endstop z system spring preview featured.jpg Endstopsistema.jpg Endstopejez.jpg Perilla.jpg
Converter M5, M8 threaded rod to leadscrew:
Allows a M5, M8 threaded rod screw instead of a leadscrew.
Adapter M5 - leadscrew - - Adapter M8 - leadscrew
Adaptador-M5-Husillo-1.jpg Adaptador-M5-Husillo-2.jpg Adaptador-M5-Husillo-3.jpg Adaptador-M8-Husillo-1.jpg
Glass clip
This part replaces the metal clip lifetime. Printers clip
Cable chain
This piece allows better ordering cables and prevent tangling with each printing. Option 1 Option 2
Layer fan
This part allows to install a layer fan in a MK8 extruder. Layer fan
Second option
Third option
Electronic protection
This piece protects the electronics inside a box. RAMPS Case
Mount for ATX-PSU power supply
This piece allows mounting a ATX power supply. Mount ATX
Montura ATX P3steel 1.jpeg Montura ATX P3steel 2.jpeg Montura ATX P3steel 3.jpeg
LM8UU Bearing printed
This piece allows replacement LM8UU bearings of a printed version. Bearing printed
Adapter for printer board endstop
This piece allows use normal Endstop instead of the micro-swith.
Adapter Z axis endstop
Endstop Z Support 1.jpg Endstop Z Support 2.jpg Endstop Z Support 3.jpg Endstop Z Support 4.jpg Endstop Z Support 5.jpg
Links
