Kid Mendel
Release status: experimental
Description | This is a highly configurable Mendel derivative built by Jungseo Park with a aesthetically simple look, driven by high-speed leadscrews.
License | GPL
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
The Kid Mendel is a printer designed by Thingiverse user JSPark, in South Korea. It is called the Kid Mendel for two reasons:
- The printer is an aesthetically simpler version of the Mendel or Prusa Mendel designs...
- Because of its simplicity, it is a good printer to use when introducing 3d printing to children.
Design
The printer follows in the footsteps of the Sells and Prusa Mendels; The extruder moves in X and Z, and the bed moves in Y. There are working Y Ends for both lead screw and belt driven. The Z axis is leadscrew driven as well. Under development are drive-trains using the Threadless Ball Screw System, which is a very nice linear motion system using 8mm smooth rod, designed by Mark Sollack (Thingiverse user MSollack) and released on Thingiverse.
The reason for all the alternative linear motion systems is preference and availability. Timing belts are hard to come by in some countries, and the quad-start high speed leadscrews specified for the printer are not available in the US.
The original design uses linear stepping motors; these are steppers that have a leadscrew machined onto the shaft. These are referred to as "leadscrew" or "leadscrew drive" through the rest of the page. With the threaded rod drive, you can use Acme leadscrews instead of traditional threaded rod, as long as the shaft diameter fits and the nuts fit....
RP Parts
The bar clamp that holds the smooth and threaded rods is the same as the Prusa Mendel's....
Bill of Materials
Under Development!!
Quantity | Description | Comments |
Fasteners | ||
100 | M8 Nut | Not all 100 are used, but it's better to have spares |
100 | M8 Washer | Not all 100 are used, but it's better to have spares |
?? | M3x10mm Screws | This number is not yet stable |
20 | M3x5mm Screws | This number is not yet stable; These are used for mounting the motors |
?? | M3 Nuts | This number is not yet stable |
Rods | ||
2 | 252mm 8mm Smooth Rod | This number is not yet stable |
1 | 300mm 8mm Smooth Rod | This number is not yet stable |
1 | 313mm 8mm Smooth Rod | This number is not yet stable |
4 | 200mm M8 Threaded Rod | This number is not yet stable |
6 | 260mm M8 Threaded Rod | This number is not yet stable |
2 | 300mm M8 Threaded Rod | This number is not yet stable |
1 | 316mm M8 Threaded Rod | This number is not yet stable |
Bearings | ||
1 | 608ZZ Roller Bearings | For Threadless Ball Screw Drive |
3 | 623 Roller Bearings | For Threadless Ball Screw Drive |
Upcoming Development
- Option for seperate lead screws
- Option for Threaded Rod XYZ axes
The original motors used are hard to source for many parts of the world; the leadscrew is attached to to the motor, instead of using a printed or machined coupler...
A known source for these for those in South Korea is http://www.motorbank.kr/shop/goods/goods_view.php?goodsno=2854&category=006006
