Kid Mendel
Revision as of 19:03, 30 July 2013 by Evamvid (talk | contribs) (RP Parts)
Kid Mendel
Release status: experimental
This is a highly configurable Mendel derivative built by Jungseo Park with a aesthetically simple look, driven by high-speed leadscrews.
GPL
The Kid Mendel is a printer designed by Thingiverse user JSPark, in South Korea. It is called the Kid Mendel for two reasons:
  1. The printer is an aesthetically simpler version of the Mendel or Prusa Mendel designs...
  2. Because of its simplicity, it is a good printer to use when introducing 3d printing to children.
Design
The printer follows in the footsteps of the Sells and Prusa Mendels; The extruder moves in X and Z, and the bed moves in Y. There are working Y Ends for both lead screw and belt driven. The Z axis is leadscrew driven as well. Under development are drive-trains using the Threadless Ball Screw System, which is a very nice linear motion system using 8mm smooth rod, designed by Mark Sollack (Thingiverse user MSollack) and released on Thingiverse.
The reason for all the alternative linear motion systems is preference and availability. Timing belts are hard to come by in some countries, and the quad-start high speed leadscrews specified for the printer are not available in the US.
The original design uses linear stepping motors; these are steppers that have a leadscrew machined onto the shaft. These are referred to as "leadscrew" or "leadscrew drive" through the rest of the page. With the threaded rod drive, you can use Acme leadscrews instead of traditional threaded rod, as long as the shaft diameter fits and the nuts fit....
RP Parts
The bar clamp that holds the smooth and threaded rods is the same as the Prusa Mendel's....
Quantity STL file Comments Picture Link
8 Bar Clamp Part taken from Prusa Mendel Design; This number is unconfirmed I2-bar-clamp.png
1 Y Idler End For Belt Drive
2 Leadscrew Backlash-Adjusting Nut Two of these are held by an LM8UU Holder; For Leadscrew Drive KM Backlash Nut in Holder.jpg
6 Frame Vertex Uses one type of vertex for the top and the bottom, instead of the classic footed/non-footed varieties KM Frame Vertex.jpg
6 Printed LM8UU This number is unconfirmed; it is recommended that you print these in PLA, and print spares for when they wear out KM Printed LM8UU.jpg
Bill of Materials
Under Development!!
Quantity Description Comments
Fasteners
100 M8 Nut Not all 100 are used, but it's better to have spares
100 M8 Washer Not all 100 are used, but it's better to have spares
Rods
2 252mm 8mm Smooth Rod This number is not yet stable
1 300mm 8mm Smooth Rod This number is not yet stable
1 313mm 8mm Smooth Rod This number is not yet stable
4 200mm M8 Threaded Rod This number is not yet stable
6 260mm M8 Threaded Rod This number is not yet stable
2 300mm M8 Threaded Rod This number is not yet stable
1 316mm M8 Threaded Rod This number is not yet stable
Upcoming Development
  • Option for seperate lead screws
  • Option for Threaded Rod XYZ axes
The original motors used are hard to source for many parts of the world; the leadscrew is attached to to the motor, instead of using a printed or machined coupler... A known source for these for those in South Korea is http://www.motorbank.kr/shop/goods/goods_view.php?goodsno=2854&category=006006
