J3dcore install
Revision as of 08:50, 7 July 2011 by Bsutton (talk | contribs)
The following attempts to describe how to install j3dcore under Ubuntu 11.04 x64.
The standard jars and .so files that ship with the reprap host application appear to be incompatible with Ubuntu 11.04. This doesn't quite make sense to me as yet I will do some more research when I'm a little less tired. In the mean time here is the fix:
Determine your java install directory;
which java
You will likely have to chase down the real directory as the above will be a symlink.
My final directory was:
/usr/lib/jvm/java-6-openjdk/jre/
Start by deleting the following files (if the exist):
lib/ext/j3dcore.jar
lib/ext/j3dutils.jar
lib/ext/vecmath.jar
Now download the latest version of the 3d libraries from:
http://java3d.java.net/binary-builds.html
I used the 1.5.2 versions.
For Ubuntu x64 you need to download:
j3d-1_5_2-linux-amd64.zip
Extract the files from the zip. (you may find an internal zip so extract that as well).
Now move all jars contained in the zip to the 'lib' directory under your reprap host install
e.g. ~/reprap/host/lib
Now move the .so file into the machine specific directory
e.g.
~/reprap/host/lib-x86_64
You should now be able to start reprap.
Alternate
You can also install these files so they are available globally (handy for debugging). In this case you need to install the jars into the jre's lib/ext directory and the .so into the lib/amd64 directory.
e.g.
sudo cp libj3dcore-ogl.so /usr/lib/jvm/java-6-openjdk/jre/lib/amd64/libj3dcore-ogl.so
sudo cp j3dcore.jar /usr/lib/jvm/java-6-openjdk/jre/lib/ext/
sudo cp j3dutils.jar /usr/lib/jvm/java-6-openjdk/jre/lib/ext/
sudo cp vecmath.jar /usr/lib/jvm/java-6-openjdk/jre/lib/ext/
