ITopie Build Manual/fr
Revision as of 13:44, 8 November 2015 by Drepou (talk | contribs) (Fabriquer la structure)
Documentation de la iTopie
Obtenez les sources
La première chose dont vous avez besoin est une copie locale des fichiers sources ( OpenSCAD , DXF , STL , etc ... ) .
La façon la plus simple de l'obtenir est de télécharger / cloner le répertoire git https://github.com/lautr3k/RepRap-iTopie .
Pour cela utiliser la commande
git clone https://github.com/lautr3k/RepRap-iTopie.git
ou
wget https://github.com/lautr3k/RepRap-iTopie/archive/dev.zip
If you do not want a customized version, you can simply use the generated DXF files in the ./build/output directory for milling/cutting your frame.
Si vous ne voulez pas une version personnalisée , vous pouvez simplement utiliser les fichiers DXF générés dans le ./build/output répertoire pour réaliser le fraisage/découpe de votre cadre .
Version Découpe CNC
./build/output/iTopie_plates-CNC-16mm_thickness.dxf
Version Découpe Laser (expérimentale)
./build/output/iTopie_plates-LaserCut-16mm_thickness.dxf
Make an custom frame
Configuration
If you want a custom frame, you need OpenSCAD to edit and parse/compile the scad source files.
After installing OpenSCAD, open it and select "Design->Automatic Reload and Compile" and "View->Hide editor".
Now you can open the ./scad/main.scad file for an live preview of all change made in the configuration file.
And then open the ./scad/config.scad in your favorite text/code editor to made change.
(Whenever the file is saved to disk (from within the external editor), OpenSCAD will recognize the file change and automatically recompiles accordingly.)
DXF files builder
The recomended way is to use the python script in the ./build directory. It will generate for you a single cleaned DXF file with layers, depending on your scad configuration file.
Usage
usage: build.py [-h] [--target int] [--output_type int] [--output_dir path]
                [--output_file filename] [--output_clean] [--tmp_dir path]
                [--tmp_clean] [--odmt path] [--scad path] [--openscad path]
                [--clean] [--version]
Options
optional arguments:
  -h, --help            show this help message and exit
  --target int
                        output version (default : 0)
                        0 : CNC milling (default)
                        1 : Laser cutting
  --output_type int, -t int
                        output type (default : 0)
                        0 : all (plate 1 and plate 2 in one file)
                        1 : plate 1 (horizontal_plate, y_carriage, feet)
                        2 : plate 2 (vertical_plate, triangles, feet)
  --output_dir path, -d path
                        path to the output directory (default : ./output)
  --output_file filename, -f filename
                        output filename without extension (default : auto)
  --output_clean        remove all files in the output directory (default : false)
  --tmp_dir path        path to the temporary directory (default : ./tmp)
  --tmp_clean           remove all files in the temporary directory (default : true)
  --odmt path           path to the OpenSCAD DXF Merge Tool (default : ../odmt/odmt.py)
  --scad path           path to the main OpenSCAD file (default : ../scad/main.scad)
  --openscad path       path to the OpenSCAD binary (default : C:/Program Files/OpenSCAD/openscad.exe)
  --clean, -c           remove all files in temporary and output directories (default : false)
  --version, -v         show program's version number and exit
Examples
python build.py -f iTopie_plates-CNC-16mm_thickness
Produces iTopie_plates-CNC-16mm_thickness.dxf in the defaut ./build/output directory.
Build manual
Frame assembly
At this point your frame is finished and functional. The following statement is optional but highly recommended.
Frame puttying, sanding, painting and lacquering
X Axis (1/2)
Y Axis
Z Axis
X axis (2/2)
Endstops
X axis
Y axis
Z axis
