I3a
Infobox info icon.svg.png This page is flagged as Advertising.
This page is found to exist for the sole purpose of Advertising, This page will eventually be removed.
Reason: stl files only available,missing sheet drawing sources, does not comply with lowest common denominator of opensource
Proposed removal date: 12/03/2015
Please use the discussion page for any questions or comments regarding this notice
Prusa i3a
i3x is a derivative of the Prusa I3.
The Prusa i3 (iteration 3) is the newest and current 3D Printer design by RepRap core developer Prusajr (Josef Prusa). The Prusa i3a is a derivative/fork that includes both adjustable bed leveling and many reinforced/improved parts.
Specifications
  • Printed Parts: 35
  • Printing Size: 9" x 9" x 6.5"
  • Precision: 50 Micron Z Resolution
Main Improvements
(main improvements made upon Josef Prusa's Prusa Mendel Iteration 3
  • Frame Stabilizers
  • Easy Assembly
  • Print friendly parts with minimal cleanup
Where to get it
Kits are not sold anymore by DIY Tech Shop, nor are assembled printers. While you could self-source your own, don't -- just build a Prusa i3 or an i3 Rework or any other printer design.
Printed Parts
The STL files to make the printer can be found at:
Stepper Motors
The Prusa i3a uses (including the Extruder), Five NEMA17 Stepper Motors:
  • Two of these Motors (the Z-Axis motors), are connected to the same Stepper Driver of the Electronics
  • If using Wade's Geared Extruder, it's Stepper Motor needs a minimum Holding Torque of 40Ncm (0.4Nm)
More information can be found on the Stepper Motor page.
Controller Electronics
Just about any RepRap Controller will work for the Prusa i3xl.
Requirements:
  • Four Stepper Drivers
  • One Thermistor Input and one Heater Output for the Extruder
For comparisons, see List of electronics, Comparison of Electronics and Alternative Electronics.
Extruder
For the Prusa i3x
It's a Greg's-Wade's extruder with toothed gears and a pre-formed slot for a groove/JHead hotend. The extruder parts available from the Prusa i3 repository are mostly compatible.
Compatible hotends:
DIY Tech Shop Crayon tip hotend -- They don't make this one either anymore.
E3d hotend
Budaschnozzle
  • Note: The Budaschnozzle doesn't mate very well with the Gregs-Wade's extruder body.
All Jhead compatible hotends...
See Also
Instructions https://shop.diytechshop.com/index.php?route=information/information&information_id=8 (also lists needed parts to build the printer)
[i3o|i3 Omega] 9X12 version.
