HuxleyMotors
Revision as of 00:08, 16 January 2011 by Kymberlyaandrus (talk | contribs) (Created page with 'border|right|400px|Image of a Huxley with the motors, belts, and endstops installed. =General= This page and its peers should guide you throu…')
General
This page and its peers should guide you through assembling a RepRap Huxley from the TechZone kit, or from parts you have printed which are the same as the TechZone parts. It is a work in progress, and needs some help, feel free to edit this document to add comments of you your own, or contact us [here] and send us messages asking us for better clarification or details.
I am starting by posting the pictures I have, and over the next few days, I will fill in the instructions and detials (24 Dec 2010)
Thanks,
Lambert (TechZone R&D/Support/Documenter)
You can access this page and it's peers (for the other parts of the Huxley assembly from the Main Huxley page or from the TechZone Huxley Page
Before installing the motors, I recommend that you hook them up to the electronics and adjust the trimpot on the electronics. The reason is that if the trimpot is up too high, the motor will get hot and warp your plastic parts. To protect your machine and all your hard work, take a few minutes to got to the first installation section of the electronics page to get the motors adjusted correctly.
Y Axis Motor, Belt and Endstop
The Y Axis Endstop and flag
Z Axis Motor, Belt and Endstop
attach the Z Axis endstop and flag
X Axis Motor, Belt, and Endstop
Parts used for the X Axis Motor, Belt and endstop
Install the X Axis endstop and flags
