Hugo
This is Hugo. Named after Hugo de Vries who introduced the term "mutation".
The entire design is done in OpenSCAD and all files are hosted on https://github.com/kr2/Hugo.
It is a derivative of the original Printrbot by abdrumm, but all parts are redesigned and improved.
Some Improvements are:
- Nut traps everywhere
- Optional cross braces
- Centered y belt
- Carriage with 3 bearings
- Belt tensioner for x and y Belts
- Additional support in y direction
Instructions
There is a H-Assembly.scad, which is not perfect but shows a complete setup of the printer. To view this H-Assembly.scad I recommend to use the actual developer release of OpenScad e.g. [3] and to set the value for "Turn off render at ... elements" [edit->Preferences] to a higher value (I use 200000).
There are several prebuilt .stl files to discover and to put your own assembly together or you build your own via OpenSCAD.
In general if you print H-Set1.stl and H-Set2.stl you should have all mandatory parts to build the printer. If you also print H-Set3.stl you should be able to setup the entire printer with reinforcements as shown in H-Assembly.scad. The H-Set7_PLA.stl contains all necessary linear bearings plus some extra, in case some come out in bad quality. This bearings should be printed in PLA because it is harder then ABS.
Print the H-TestObject.stl first to check the quality of your prints. It has the main difficulties of the printed objects in one part.
Bill of Materials
Printer Quality Test
Quantity | Picture | Description | Material | DownloadLink |
1 | Quality Test Object | PLA / ABS |
There are 3 different models available:
Pb_Standard: It uses T5 belts which are commonly uses
Hugo_Standard: It uses T2.5 belts. This printer has been successfully sliced with Slic3r 0.72b and 0.32mm Layer
Hugo+: Tt uses T2.5 Belts and is designed for 12mm Z-Rods. This printer has been successfully sliced with “skeinforge” and 0.25mm Layer
The table shows only a selection of parts. Additional parts and alternative layouts for some parts you will find on “github”
The download-link opens the files for a Hugo_Standard.
Basic Printed Parts
1 | Base Set | PLA / ABS | .stl File | |
1 | Y-Belt Divert | PLA / ABS | .stl File | |
1 | Y-Bar End | PLA / ABS | .stl File | |
1 | Bearing Guide Set | PLA / ABS | ||
1 | Endstop Holder Set | PLA / ABS | ||
1 | Y-Belt Clamp Set | PLA / ABS | ||
1 | X-End Set | PLA / ABS | ||
1 | X-Carriage | PLA / ABS | ||
1 | X-Etruder Mount | PLA / ABS | ||
1 | Gregs Extruder | ABS | ||
1 | Extruder Gears Set | PLA / ABS | ||
1 | Y-End Foot Set | PLA / ABS | ||
1 | Y-Bar Clamp Set | PLA / ABS | ||
1 | Z Cupling Set | PLA / ABS | ||
0 | Print Set1 | PLA / ABS | ||
0 | Print Set2 | PLA / ABS | ||
0 | Print Set3 | PLA / ABS |
Additional Printed Parts
Electric and Elektronic
Any of the commonly known boards will do: Arduino[4] with RAMPS[5]; Sanguinololu [6]; Printrboard [7];
Bolds
Amount | Size | Lenght |
6 | M2.5 | 12mm |
13 | M3 | 10mm |
13 | M3 | 15mm |
6 | M3 | 25mm |
3 | M3 | 35mm |
3 | M8 | 30mm |
Nuts
Amount | Size |
6 | M2.5 |
20 | M3 |
48 | M8 |
Washers
Amount | Size |
6 | M2.5 |
35 | M3 |
48 | M8 |
Threaded Rods
Place | Amount | Size | Lenght |
Base | 4 | M8 | 310mm |
Z-Axis | 2 | M8 | 310mm |
Smooth Rods
X-Axis | 2 | M8 | 330mm |
Y-Axis | 2 | M8 | 330mm |
Z-Axis | 2 | M8 | 330mm |
www.reprap.org/wiki/Hugo_Build
Sources
Bar clamp: Bar clamp by Josef Průša [8]
Bearing Guide: Bearing Guide by GregFrost [9]
Also some modules and metric files from the two above.
Extruder: Greg's Wade reloaded - Guidler, Tilt Screws, Fishbone Gears by jonaskuehling [10]
Printrbot: THE Printrbot by abdrumm [11]
Thanks to all of them.
