Hugo
Release status: experimental
This is Hugo. Named after Hugo de Vries who introduced the term "mutation".
The entire design is done in OpenSCAD and all files are hosted on https://github.com/kr2/Hugo.
It is a derivative of the original Printrbot by abdrumm, but all parts are redesigned and improved.
Some Improvements are:
- Nut traps everywhere
- Optional cross braces
- Centered y belt
- Carriage with 3 bearings
- Belt tensioner for x and y Belts
- Additional base in y direction
Instructions
There is a H-Assembly.scad, which is not perfect but shows a complete setup of the printer. To view this H-Assembly.scad I recommend to use the actual developer release of OpenScad e.g. [3] and to set the value for "Turn off render at ... elements" [edit->Preferences] to a higher value (I use 200000).
There are several prebuilt .stl files to discover and to put your own assembly together or you build your own via OpenSCAD.
In general if you print H-Set1.stl and H-Set2.stl you should have all mandatory parts to build the printer. If you also print H-Set3.stl you should be able to setup the entire printer with reinforcements as shown in H-Assembly.scad. The H-Set7_PLA.stl contains all necessary linear bearings plus some extra, in case some come out in bad quality. This bearings should be printed in PLA because it is harder then ABS.
Bill of Materials
Basic Printed Parts
Quantity | Picture | Description | Material | DownloadLink |
1 | Base Set | PLA / ABS | ||
0 | Base Left | PLA / ABS | ||
0 | Base Right | PLA / ABS | ||
1 | Y-Belt Divert | PLA / ABS | ||
1 | Bearing Guide Set | PLA / ABS | ||
0 | Bearing Guide | PLA / ABS | ||
1 | 50px | Y-Belt Clamp Set | PLA / ABS | |
0 | Y-Belt Clamp | PLA / ABS | ||
1 | X-End Set | PLA / ABS | ||
0 | X-End Motor | PLA / ABS | ||
0 | X-End Idler | PLA / ABS | ||
1 | X-Carriage | PLA / ABS | ||
1 | X-Etruder Mount | PLA / ABS | ||
1 | Bar Clamp Set | PLA / ABS | ||
0 | Bar Clamp | PLA / ABS | ||
1 | 50px | Y-End Foot Set | PLA / ABS | |
1 | 50px | Z Cupling Set | PLA / ABS | |
0 | 50px | Z Cupplig | PLA / ABS | |
0 | Print Set 1 | PLA / ABS | ||
0 | Print Set2 | PLA / ABS |
Electric and Elektronic
to be done
Nuts and Bolds
to be done
Sources
Bar clamp: Bar clamp by Josef Průša [4]
Bearing Guide: Bearing Guide by GregFrost [5]
Also some modules and metric files from the two above.
Extruder: Greg's Wade reloaded - Guidler, Tilt Screws, Fishbone Gears by jonaskuehling [6]
Printrbot: THE Printrbot by abdrumm [7]
Thanks to all of them.
