How to Print RepRapPro Huxley
Revision as of 13:40, 19 January 2012 by Adrianbowyer (talk | contribs) (Print a RepRap Huxley on a RepRap Huxley)
Introduction
You can print all the plastic parts for a complete RepRapPro Huxley in another Huxley or any other model of RepRap, of course. The RepRapPro Huxley on the right has just printed the last of four trays of parts for a copy of itself.
You can also print them using virtually any other 3D printer such as a MakerBot or Stratasys or Cube. (The only 3D printers known not to work are ZCorp powder printers - their manufactured parts are too weak.)
This page tells you all you need to know in order to print a Huxley for yourself, for a friend, or for sale.
How much plastic?
One complete set of polylactic acid (PLA) printed RepRapPro Huxley parts has a mass of about 260 grams. (Note that this mass does depend on your print settings: the closer the infill the denser the parts.)
260 grams of 1.75mm diameter PLA is about 87 meters of filament.
260 grams of 3mm diameter PLA is about 30 meters of filament.
ABS has a slightly lower density than PLA, so the mass will be lower for that. The volumes and filament lengths will be the same, of course.
A tray is one set of parts printed to fill the Huxley bed.
There are four trays to download and print:
Tray Right mouse click and select "Save as..."
Reprappro-huxley-huxley-tray-1.png https://github.com/reprappro/Huxley/raw/master/Print-Huxley/Huxley-trays-STLs/huxley-tray-1.stl
Reprappro-huxley-huxley-tray-2.png https://github.com/reprappro/Huxley/raw/master/Print-Huxley/Huxley-trays-STLs/huxley-tray-2.stl
Reprappro-huxley-huxley-tray-3.png https://github.com/reprappro/Huxley/raw/master/Print-Huxley/Huxley-trays-STLs/huxley-tray-3.stl
Reprappro-huxley-huxley-tray-4.png https://github.com/reprappro/Huxley/raw/master/Print-Huxley/Huxley-trays-STLs/huxley-tray-4.stl
That's it! Printing those four will give you one full set of RepRapPro Huxley printed parts.
Print a RepRap Huxley on a RepRap Mendel
This works for either the standard Mendel or the Prusa Mendel.
