Hall-O DIY kit
Description | Hall effect endstop sensor
License | Attribution - ShareAlike
Author | |
Contributors | |
Based-on | [[]]
Categories | |
CAD Models | see files
External Link |
The brave that want to solder the Hall-O themselves, will get all the info required, to do so.
If this is the first time you solder SMD, you have chosen a nice project to begin with.
After this one, you will agree that soldering SMD is easier and faster then through hole.
Content of bag
There is a small magnet in the bag, so be careful when you open it.
Content :
- ziplock bag
- Hall-O pcb
- paper containing components
- 1m cable
- magnet
Content of paper
Soldering
First of all make sure your soldering iron has a tip of 0.4mm, and make sure its clean.
That part is so important, when soldering SMD, that I will repeat it: make sure the tip is clean.
Clean means, there is no rest tin on it, but also means that when you hold tin to it, the tin immediately flows. So without pressing the tin to the tip.
If it does not flow, cool the iron, and clean it with a knife. Do not cut but rather scrape the tip and then heat it back up while holding tin to it.
Now you have a proper working soldering iron.
When soldering SMD always start with the smallest components and work your way up.
Put tin on 1 pad on the board, place the component with tweezers and hold, solder that 1 pad and then the other(s).
The last component will be the hall sensor itself. Put the pins in the holes and bend the pins 90 degrees. Now the sensor is aligned with the board.
Cut the pins so they do not stick out on the other side(1mm)
Note that the sensor should stick out about 2 mm from the board, to ensure you can bend the sensor in a 90 degree angle opposed to the board.
