HackerBot door
Revision as of 09:18, 14 February 2014 by Balestrino (talk | contribs) (Created page with "{{RepRapNavigation|name=HackerBot}} ====Step 31: Door assembly==== {| {{table}} border=1 |+ '''Door''' | width="50" align="center" style="background:#f0f0f0;"|'''qty''' | wi...")
HackerBot Documentation
qty | part name | description/notes |
1 | Door PMMA panel | |
2 | Aluminum extrusion profile 20x20 length 405mm | |
2 | Aluminum extrusion profile 20x20 length 382mm | |
4 | Cubic joint 20x20 2 way | Bosch 3842524484 |
2 | Hinge | Bosch 3842544526 |
1 | Handle | what you like! just use a small cube |
Create a square with the four 20x20 profiles, in the vertex insert the cubic joints
'Remember the M4 hole & fasten the handle on a 382mm extrusion
Insert PMMA panel before tighten screws:
Use hinges to place door on the front of the printer
** DOOR COMPLETE **
