Graber i3/fr
Release status: Working
Description | Prusa i3 est un projet mené par S.Graber
License | |
Author | unknown
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Dépot Github oficiel de la Graber i3: [1]
Derivé du design de la Prusa i3 La Graber est concue pour qu'un maximumù de pieces soient découpées au laser
Espace utile: 200 x 200 x 200 mm
Liste de materiel
This list may be incomplete! traduction en cours
M3 nuts will be to small for the provided slots (thus the strikethrough); M5 nuts would be wide enough, but the screw holes only have a diameter of 3.5mm.
One possible solution is to use M3 nuts+M3 washers. Find some M3 washers that have an outer diameter of 8mm, and use one washer per screw to make it a secure fit.
Prevoir une plaque de MDF 6mm de 810x460mm
Qté | Métric | Imperial |
2 | M5 x 292mm | 5mm x 11.5" (Z) |
2 | M8 x 51mm | 5/16" x 2" (Y) |
Qt | Metric | Imperial |
2 | 8mm x 317mm | 8mm x 12.5" (Z) |
2 | 8mm x 342mm | 8mm x 13.5" (Y) |
2 | 8mm x 400mm | 8mm x 15 3/4" (X) |
Qt | description | mots clefs anglophone | - | 15 | M3 x 10mm (pour les moteurs) | - | 6 | |
6-32 x 0.5" | - | 41 | |
6-32 x 3/4" | - | 4 | M3 x 20mm (Lit chaufant) | - | 3 | M3 x 25mm (montage RAMPS) | - | 2 | |
6-32 x 1" | - | 4 | |
6-32 x 1,1/4" (X-Car) | - | 8 | |
6-32 x 1,1/2" |
Qt | Metric | Imperial | - | 7 | ecrou M3 Nyloc | M3 Nut Nylon Insert | - | 61 | Ecrous Nylon Insert | Nut 6-32 Nylon Insert | - | 2 | Ecrous M5 | - | 2 | Ecrous M8 | Nut 5/16" |
6 | rondelles M3 | Washers 6-32 |
2 | rondelles M8 | Washers 5/16" |
Qty | Item | |
4 | Pinces dessinateur (tenir le lit chaufant) | |
7 | Collier de serrage en plastique 10 cm (Zip Tie) | |
2 | Roulements à bille 608zz (X-Y) type rollers | |
2 | Flexible 5 mm x 5 mm ou 20mm de tube PVC (accoupler axes Z) ex tuyau air aquarium ou osmoseur | |
10 | LM8UU cage à bille | |
1 | Extrudeur | |
1 | Roue d'extuder | |
2m | couroie GT2 6mm de large | (7 feet) GT2 belt 6mm width |
2 | Poulie aluminium taille GT2 - 20 dents | GT2 20-Tooth Pulley 5mm Shaft |
Qty | Item | mots clefs |
1 | Arduino Mega2560 R3 ATmega2560 | |
1 | Shield arduino RAMPS 1.4 | |
1 | Lit chaufant | MK2B Dual Power PCB Heat Bed |
3 | cateur Micro Switch (fin de course) | |
1 | Ecran RAMPS 1.4 LCD12864 Intelligent Controller LCD Control Board (optionel) | |
5 | moteurs pas à pas Nema 17 | |
5 | drivers A4988 | |
1 | alimentation 12V 15A (200W) |
