Generation 7 Electronics
Revision as of 11:08, 24 December 2010 by Jacky2k (talk | contribs)
Release status: Experimental
GPL v2
This is a complete set of electronics loosely based on the (a bit unfortunately named) Gen2OnABoard. It has many features in common with the various Pololu_Electronics variants. So you can as much call it based on RAMPS, as it's a step forward to simplicity and lower price by replacing the Arduino Mega, which is rather a heavyweight for the task at hand, by a simple, cheap, easily solderable (DIP housing) ATmega controller chip.
Design Goals
  • PCB easy to manufacture on a RepRap.
  • All parts on one board. Except for the Opto Endstops, of course.
  • Enough components to run a Mendel or Huxley with extruder and heated bed.
  • Easy to set up. For example, this would include an USB port.
  • Well available and cheap parts.
  • Based on the ATmega644.
  • Well suited for community driven development.
Features
  • Single board solution.
  • Single sided PCB.
  • Pololu stepper drivers, exchangeable.
  • 4x stepper motor drivers with 1/16 microstepping.
  • TODO: on-board USB-RS232 converter.
  • Integrated hardware for driving one extruder (stepper, heater and thermistor).
  • Integrated hardware for a heated bed (heater, thermistor).
  • Integrated hardware for driving a fan.
  • Ready to be hooked up on a generic PC power supply unit (PSU).
  • Use of standard connectors.
  • Debug LEDs for power, Fan and both heater outputs.
  • Can turn PSU on and off in software.
  • Reset button.
Specifications
  • Dimensions about 100 x 120 mm.
  • Input voltage through a 20-pin PC PSU and a 4-pin Molex or the 4-pin Molex alone (which allows higher voltages for the motors/heaters).
  • Processor: ATmega644 (Atmel Corp.)
More to be defined.
Development
Status
A first version of the Gen7 board has been etched and is beeing tested.
Layout, PCB Editing
Gen7 uses gEDA, a true open source set of Electronics Development Tools (EDA). While gEDA has a bit of a learning curve and has some room for improvement regarding the graphical user interface, it's reliable, fast and well suited for the task. gEDA is available for Linux and Mac OS X and has ready-to-use packages on Debian/Ubuntu and SuSe. To install it on Ubuntu, simply type
sudo apt-get install geda geda-utils geda-xgsch2pcb
and you'll find schematics and PCB layout editor applications in your applications menu.
Typical Work Loop
RepRap is all about evolution of machines and lowering entry barriers into their (self-)replication, so here you have an easy how-to type description of a typical work loop for changing these electronics with the gEDA/PCB tool chain.
Download the files with Git or GitHubs download button. In the later case choose to download source and unpack that when done.
  • Always start editing with the project (.gsch2pcb suffix) file. You can open it by double-clicking it.
  • Select the schematics and use the button below the list to open it.
  • When done, save it and return to the project.
  • Open the PCB using one of the buttons to the right. Both have almost the same functionality.
  • If you have choosen to update the PCB, footprints no longer in use will have vanished and new or previously missing ones appear in the upper left corner. An updated list of connections (netlist) will have been loaded. Update the rats nest to find areas requiring work.
You get the idea?
PCB Manufacturing
gEDA can export PCBs to the Gerber and other file formats, of course. On how to proceed further with that, see the PCB Milling page.
Bug fixing, Sending Changes
This is community development, so getting changes from everyone is more than welcome. Write them to the forum, to the reprap-dev mailing list, use GitHub's Issue Tracker, whatever is most convenient for you. If you fork the repository at GitHub, you can also send Traumflug pull requests.
