Genealogy / Archeology of the Greg's Wade's Geared Extruder
In this page I will illustrate (to the best of my knowledge) how the original design for the Wade's geared extruder has evolved in the last few years. Nowadays (early 2015) this extruder design is probably the most popular single extruder design among reprappers worldwide, and it has spawned countless remixes. It would be impossible to account for all the variants of this design available on the web but I will try my best to show its main "evolutionary line".
- 1 1st Gen: Wade's original design
- 2 2nd Gen: (Greg's) Accessible Wade's Extruder
- 3 3rd Gen: Greg's Hinged Accessible Extruder
- 4 4th Gen: Greg's Guidler
- 5 5th Gen: Greg's Wade reloaded
- 6 Concurrent 6th Gen popular designs: Misan's "Bob's your uncle" and the i3 Rework rotated versions of Greg's Wade's Geared Extruder
This is actually documented right here in the wiki: Wade's_Geared_Extruder and you can find all the files for it on that same page.
Now, I understand that the original Wade's geared extruder from February 2010 is itself an evolution of an earlier extruder design by Adrian Bowyer and also includes many ideas from Nophead's early research on extruders. It seems it was not designed in OpenSCAD and I don't have any information on what CAD program Wade used.
All the files for this early extruder design are still available both here on RepRap.org and also on Thingiverse, however one should note that it has been improved upon. See below.
This was published on Thingiverse in February 2011 i.e. about a year after the publication of the original Wade's extruder.
The OpenSCAD source includes references to Josef Prusa's GitHub repository so I imagine the extruder was designed to be used with the Prusa Mendel, at the time the "current" Prusa design.
File header:
- // Greg's Wade Extruder.
- // It is licensed under the Creative Commons - GNU GPL license.
- // © 2010 by GregFrost
- // Extruder based on prusa git repo.
About a month later Greg published version 2 of his extruder, which is pictured below:
(add picture)
Greg published the third version of his extruder on Thingiverse in May 2011, about two months after the publication of version 2. The main improvement is of course the addition of a hinged idler, as the name of the thing indicates. This is how Greg describes his improvements:
- This is an update to my Accessible Wade's Extruder.
- The idler is now hinged using an M3 screw. I have also added support for the central part of the 608 idler so that there is no need to use washers to space the bearing away from the plastic.
- I have been using this design for a while now and love it.
- Changing filament is a simple as compressing the spring then whipping out the old filament and poking the new one in.
(add picture)
The Thingiverse page shows this design was remixed 29 times!
In February 2012 Greg came up with a 4th version of his extruder design, published on Thingiverse as "Guidler for a Gregs Wade", although the newly published thing was really a complete extruder.
Now, why did Greg use the previously unheard of word "guidler"? In Greg's own words:
- Some minor changes to my filament pusher inspired by Tom's update (http://www.thingiverse.com/thing:16928). I have incorporated a filament guide on the idler (and coined the term guidler). I also took his modification so the front bearing doesnt rub and I have included a printed spacer so the bottom bearing doesnt rub either (just insert it before the bearing). I also widened the opening a bit for better access to the hobbing (another of Tom's ideas). I also included one of Triffid Hunter's suggestions to modify the hinge support piece slightly to make it easier to remove.
- Thanks Tom and Triffid for the ideas.
(add picture)
This thing was remixed 15 times on Thingiverse and among the remixes we'll find what I consider to be the following "evolutionary step" for this extruder design, Greg's Wade reloaded.
In March 2012, just one month after Greg had published version 4 of his extruder, Jonas Kuehling published his "reloaded" version of Greg's Wade's Geared Extruder on Thingiverse. The list of improvements/modifications is quite extensive:
- This derivative of Greg's Wade Extruder collects all the best ideas and latest features and improvements:
- * Greg's excellent "Guidler" for perfectly lined up filament feed AND easy access of the hobbed bolt
- * Tiltable idler-screws for opening the idler without removing the screws entirely
- * 4mm elevation of whole extruder body/bolt/motor mount to allow slightly bigger 9/47 herringbone gears
- * 2mm extra bolt-motor-distance for the same reason
- * M4 nuts and screws for idler, since M3 screws in more than 60mm length are sometimes hard to source (at least in the common hardware stores of northern germany..)
- * Well, 9/47 herringbone gears!
- * All nut-traps have been corrected for correct fit (all prusa parts seem to use slightly wrong sizes.. should be 5.5mm wrench size for M3 nuts, I changed all of them to the right ISO values with additional 0.2mm clearance. Fits great for a precisely calibrated prusa)
- * Additional hotend-mount option "reprapfaborg" for Stoffel15's great hotends that use 10mm shaft diameter of 20mm length (shown on one of the pictures as a cut-view); you can get one via http://reprap-fab.org
- * 8mm thickness of motor mount (instead of 10mm) in reference to wider herringbone gear
(include picture)
It is quite interesting that Jonas adopted the word "guidler" just one month after Greg had coined it; my guess is the idea was so good that it needed the obvious name that Greg has given it. Another interesting fact is that Jonas' work had so many derivatives (Jonas' thing was remixed a grand total of 67 times!) that 3 years later it has become difficult to distinguish a single evolutionary path, as there are many derived extruder designs that are available on the web. Another issue that clouded the evolutionary path here is that Jonas did not add his copyright to the source code, and the only way to distinguish his changes to the source code is using a diff-style program (an automated program that lists the differences between two text files).
I have chosen only two among the dozens of derivatives of Greg's Wade's Geared Extruder available nowadays (early 2015) to show how the design evolved (and is still evolving!) in the last three years.
Misan's "Bob's your uncle" version of Greg's Wade's Geared Extruder was published in March 2013 on Thingiverse and designed for the Prusa i3, the design of which had just been published by Josef Prusa. The Prusa i3 was the "hot new kid on the block" among 3D printer designs at the time and Misan's "Bob's your uncle" version of Greg's Wade's Geared Extruder almost immediately became extremely popular among reprappers building an i3 or even considering a build.
(include picture)
The i3 Rework version of Greg's Wade's Geared Extruder is slightly more original in the sense that it rotates the whole body of the extruder in relation to the X-axis: the gears are now perpendicular to the X-axis. This in fact leads to a rearrangement of the various elements of the extruder but still, it retains all the features that the Greg's Wade's Geared Extruder is known for.
(include picture)
