Gen L Electronics
Revision as of 22:54, 22 June 2011 by Loganb (talk | contribs) (Added an image for the category box)
Generation 'L' Electronics
Release status: designed
GenL Electronics is (currently hypothetical) design for extremely low cost
GPL v2
Overview
Generation "L" electronics are a still unassembled 4-axis motor controller platform designed to be very easily assembled and relatively cheap. Total electronics cost (including opto-endstops and other off-board parts) is under $70 when ordered in 1-board quantities. It uses two circuit boards: one for power, one for logic. The boards can be manufactured in China for $3 and $2 respectively (lots of 10). Total part count is ~80 and all but 1 are through-hole for easy hand soldering.
The motors are controlled by Allegro A3992 stepper drivers via SPI. This controller is capable of 1/32-microstepping and the Teensy should be able to comfortably achieve full precision at speeds under ~4 inches/seconds. At higher speeds the resolution will gracefully degrade to 1/16th-microstepping.
The latest development code is available at: https://github.com/loganb/GenL
Software
Software for the board is as-yet, unwritten. The goal is to use the Teensy to do only the minimal work necessary to drive the controllers and read the sensors, leaving complex, floating-point math to the done on a host computer. The Teensy has a full-speed USB interface built-in for easy programming and interfacing.
Hardware
