FoldaRap power-supplies
Revision as of 18:24, 18 March 2014 by Emmanuel (talk | contribs) (grouping foldarap power supply pages)
>>Back to Y-motor or Underplate section
120W "led" (FoldaRap 1.1 and 2)
Low Profile 120W (FoldaRap 1.1 and 2
The 120W power supply is a generic power supply, but with a low profile (34mm).
  • Power supply to male plug : 1 green wire 18WG of 15cm, one end with ferule, the other end just stripped
  • Switch to power supply : 1 red and 1 black wire 18AWG of 15cm, one end with ferule, the other end just stripped
  • Switch to male plug : 1 red wire of 6cm, 1 black of 9cm 18AWG, both ends with ferule
  • board to power supply : 8 cm red/black wires
Low Profile 240W (FoldaRap 1)
The 240W power supply is a TXH240 [1]. It was replaced by a 120W power supply after we realized the first one was a little overkill (and costly, the 120W is ten times cheaper).
  • Power supply to male plug : 1 green wire 18WG of 35cm, one end with ferule, the other end just stripped
  • Switch to power supply : 1 red and 1 black wire 18AWG of 35cm, one end with ferule, the other end just stripped
<videoflash>BiiBkZKw1og|320|240</videoflash>
<videoflash>_tXWGjJq0zM|320|240</videoflash>
  • Bolt the PSU on the plate, with a washer between the psu and the plate
<videoflash>o5W4oZXCXOw|320|240</videoflash>
Underplate
Wiring
The following wiring diagram of the Azteeg X1 board might help if you can't read the inscription on the board.
  1. Y-motor (15cm, under the board)
  2. X-motor (50cm)
  3. Z-motors (17cm and 25cm)
  4. Extruder-motor + fan
  5. Y-endstop (green 32cm)
  6. Z-endstop (blue 25cm)
  7. X-endstop (red 50cm)
  8. Hotend-thermistor (blue 60cm)
  9. Hotend-resistor (red 60cm)
  10. Hotend-fan (red/black 60cm)
  11. Bed-thermistor (blue 30-35cm)
  12. Bed-peltier
<videoflash>HCyQjKg8jjU|320|240</videoflash>
