FoldaRap Y-motor AzteegX1 240W
Revision as of 19:53, 9 June 2013 by Emmanuel (talk | contribs) (Created page with '>>Back to FoldaRap_Build_Manual#Y-motor The 240W power supply is a TXH240 [http://www.rs-particuliers.com/WebCatalog/Alimentation_%C3%80_Decoupage_12v_20a_240w-7066316.aspx]…')
The 240W power supply is a TXH240 [1]. It was replaced by a 120W power supply after we realized the first one was a little overkill (and costly, the 120W is ten times cheaper).
- Power supply to male plug : 1 green wire 18WG of 35cm, one end with ferule, the other end just stripped
- Switch to power supply : 1 red and 1 black wire 18AWG of 35cm, one end with ferule, the other end just stripped
<videoflash>BiiBkZKw1og|320|240</videoflash>
