FoldaRap Y-motor AzteegX1 240W
Revision as of 18:25, 18 March 2014 by Emmanuel (talk | contribs) (Redirected page to FoldaRap power-supplies)
Redirect page
Redirect to:
>>Back to FoldaRap_Build_Manual#Y-motor
The 240W power supply is a TXH240 [1]. It was replaced by a 120W power supply after we realized the first one was a little overkill (and costly, the 120W is ten times cheaper).
- Power supply to male plug : 1 green wire 18WG of 35cm, one end with ferule, the other end just stripped
- Switch to power supply : 1 red and 1 black wire 18AWG of 35cm, one end with ferule, the other end just stripped
- board to power supply : 8 cm red/black wires
<videoflash>BiiBkZKw1og|320|240</videoflash>
<videoflash>_tXWGjJq0zM|320|240</videoflash>
- Bolt the PSU on the plate, with a washer between the psu and the plate
<videoflash>o5W4oZXCXOw|320|240</videoflash>
Underplate
Wiring
The following wiring diagram of the Azteeg X1 board might help if you can't read the inscription on the board.
- Y-motor (15cm, under the board)
- X-motor (50cm)
- Z-motors (17cm and 25cm)
- Extruder-motor + fan
- Y-endstop (green 32cm)
- Z-endstop (blue 25cm)
- X-endstop (red 50cm)
- Hotend-thermistor (blue 60cm)
- Hotend-resistor (red 60cm)
- Hotend-fan (red/black 60cm)
- Bed-thermistor (blue 30-35cm)
- Bed-peltier
<videoflash>HCyQjKg8jjU|320|240</videoflash>
