FoldaRap Melzi
>>Back to FoldaRap_Build_Manual#Electronic_Board
- It is maybe a good time to check if the stepper drivers are correctly set
- refer to Melzi and RepRapPro_Setting_Motor_Currents (Vref = 0.4 for the nema14 and 0.44 or 0.45 for the extruder one)
- usually you don't need to plug the power supply for that, if you have set the jumper to "usb" instead of "int", the board will be powered via the USB connection (it's ok for just checking the Vref, but it will never be enough to move or heat something).
Wiring (45-60 min)
Now lets plug everything to the board ! The Melzi is well legended and the wiring should be straightforward.
- 18 AWG : power
- board to power supply : 15 cm red/black wires
- 22 AWG : heat
- 26 AWG : sensors/motors (you may use the leftover from the motors)
Tips : if you don't have a ruler, the big alu profiles are 300mm long, e.g. : count twice the side of the machine to have enough length for the hotend and a little margin
- Y-motor (~30cm)
- Z-motors (~20cm and 25cm)
- X-motor (50cm)
- Extruder-motor + fan (50cm)
- Y-endstop (green 32cm)
- Z-endstop (blue 25cm)
- X-endstop (red 50cm)
- Hotend-thermistor (blue 60cm)
- Hotend-resistor (red 60cm)
- Hotend-fan (red/black 60cm) : directly wired on the 12v from the psu, or with the 12v input on the board
- Extruder-stepper fan: same
- (Optional) printed-part cooling fan: on the fan port, as most of the boards have one (turned on by sending Mcode "M106 Sxxx" (xxx being between 0 and 255), turned off by "M107" but Slic3r automate this)
- Bed-thermistor (blue 35cm)
- Bed-peltier
- Finish by the bed wires (peltier and thermistor), as they will move they need to be above all the other wires.
- Melzi, red, blue, green, black, from right to left (http://reprap.org/wiki/File:Reprappro-mendel-melzi-cons.jpg) RepRapPro_Mendel_wiring#Connections_to_the_controller_board
