FoldaRap Buyers Guide/zh cn
Revision as of 11:29, 7 December 2013 by Iggcel (talk | contribs)
Index | | 如何获得 FoldaRap | 如何构建 FoldaRap | 如何使用 FoldaRap | FoldaRap improvements
This project was for myself, as I need/want a RepRap that's easy to carry around and for the challenge of making a folding 3d-printer. But I believe in open-source and sharing and all the revolution behind that. Thus I try to well document it, in case others want to make one; to acknowledge all the things we own to those who went before, and to encourage those who come after to do the same. On a more long-term view, I don't plan to create a company out of it, I'd better hope to see it grow on itself in the wild, just by indicating how to source it. I have more fun in designing stuff than marketing it, nonetheless I may try to sell few beta-test kits (bulk ordering is good for prices), eventually via a crowdsourcing campaign or by request, maybe with the help of my hackerspace. Just for the experience of it and to say I can push a project to that point :D (edit : done !) (almost all the projects I did during my design studies could have done something, but I never found the time for that and they ended sleeping in their drawing books which is sad; while now I have taken the habit to publish everything, even an old one sometimes). "Ideas are like living things and breed happily in an open-source context" as I like to think ^^ (on the same spirit I like this comment from User:Adrianbowyer)
物料清单 (BOM)
一台机器的总成本:包含所有的税收与运费在500至600欧元。 我建议你与朋友团购或在本地采购。
硬件
(PS:因各国对材料的型号表示不同,本人非专业,材料建议自己看英文理解)
5 根 20x20mm梁 6mm槽 200mm长 铝材
5  20x20mm beam 6mm slot 200mm - Motedis 或看 Aluminium_profile_Suppliers
6 根 20x20mm梁 6mm槽 300mm长 铝材
6  20x20mm beam 6mm slot 300mm
50 对 用于6mm槽的M4四角螺母
50 M4 T-nut for 6mm slot - Motedis
(=31€)
50 M4x8 round head bolt - Fix'n Vis Round Head Bolt
2  M3x4 / Hotend-heatsink(2) Fix'n Vis Bolts
13 M3x8 bolt / Z-motors (4), Y-motor (3), X-end-idler (2), psu (2), male plug (2)
2  M3x10 bolt / Hotend-heatsink (2)
6  M3x12 bolt / X-idler (1), extruder-idler (3), Y-belt-clamp (2)
4  M3x16 bolt / X-motor (3), extruder-fan (1)
7  M3x20 bolt / X-carriage (3), hinges axis (2), Y-idler (1), extruder-idler (1)
3  M3x30 countersunk bolt / bed leveling (3)
2  M3x35 / extruder spring (2)
19 M3 nut / hinges (2), X-carriage (3), X-idler (2), extru-fan (1), Bed (3), Y-belt-clamp (2), extru-idler (2), plug (2), psu (2) - Fix'n Vis Nuts
3  M3 nylock nut / bed leveling (3) nylock nut
5  M5 nut / extruder-idler pneumatic fitting (1),z-rod (4) (for the Z nylon nuts can be slightly better)
11 M3 washer / X-motor (3), X-idler (2), extruder-idler (2), Y-idler (2), Y-belt-clamp (2) - Fix'n Vis washer
2  230mm threaded rod M5 - Fix'n Vis
(=9€)
2  extruder spring - RS751483 or see Springs
3  bed spring - RS 751455 or RS 751607
1m spiral wrapping band for tidying the wires - RS227874
7  faston ferule - Radiospare to crimp the cable for the plug and the switch
(=15€)
2  polymer coupling - See this thread (ebay / emakershop)
6  linear bearing, LM6UU or if you can Igus RJMP-01-06 - See Bearing
4  300mm smooth rod 6mm - (can be salvaged from usual scanners and printers) or see Smooth rod
4  603zz bearings / X-idler (1), Y-idler (2), extruder-idler (1)  - See Bearing
1  600mm T2.5 belt 5-6mm wide - RepRapWorld or see Belts_and_Pulleys
1  700mm T2.5 belt 5-6mm wide
2  T2.5 pulleys - Paoparts or see Belts_and_Pulleys
1  PTFE Tubing for bowden extruder (2mm inner diam. and 3mm outer), 300mm long - See Bowden
2  Pneumatic fittings for 3mm tubing, with M5 thread - See Bowden or emakershop / I'm using the MA12-03-M5 but others can work
1  direct drive gear - Maritime-models (see Drive-gear)
1  bed plate 4mm thick - Paoparts
1  roll of kapton - See Kapton Tape#Vendors
20-30 zip-ties
电子部分
5 nema14 stepper motors - [1]
5个NEMA14 步进电机
1 usb to mini-usb cable - [2]
1条usb转mini-usb的电缆
3 miniature microswitch endstop 20mm - [3]
3个微型的微动开关 限位定档 20mm
1 standard male plug IEC C13 C14 - RS 5392045
1 个标准插头 IEC C13 C14
1 standard female cable - EU/C13 - UK RS6266739 / US RS7316163
1个标准阴型电缆
1 big blue switch - RS 5287858
1个蓝色大开关(为什要说明是蓝色的?)
1 RepRappro Hotend - emaker
1 40x40mm heatsink - RS 6744769 to make a more compact hotend
1-2 small fan (40 x 40 x 10 mm), for the hotend (can be bought with one) and the extruder motor - RepRapWorld or see Fan
1 100k thermistors - Mouser
1 m of 18AWG wire (350mm red, 300m black, 150mm green) for the switch/plug/psu - Read also WiresAndConnectors
1,5 m of 22AWG (red or black) for the hotend heater (not needed if you buy a cartridge heater, they usually come with 100cm wires)
10 m of 26AWG (3.6m red, 3.2m green, 2.0m blue) for the sensors and fans
1 Melzi board [4]
1 12V power supply : 5A or 10A (for heated bed)
or
1 Azteeg_X1 board - [5]
4 stepper drivers
1 12V power supply : 10A or 20A (RS 7066316 100*150*35mm)
激光切割部分
请看 github repoeMakerShop, 你还可看这里 Ponoko
1 electronic under-plate 3-4mm thick
1块3至4mm厚的电路板
1 bed-plate 4-6mm thick (acrylic or aluminium)
1块3-4mm厚的基坐板(亚克力或铝板材)
1 Y-carriage
1块立箱板
1 reprap.org plate 160x20mm, 2-4mm thick (+2 T-nut and M4x8) - optional but make a nice reference to the wiki :)
1块160x20mm, 2-4mm厚(+2 四角螺母 和 M4x8)印有reprap.org的Logo板 - 可选的,但好引用wiki 呵呵:)
打印部分 (total : 21)
See also the github repo
foot front left
foot front right
foot rear left
foot rear right
hinge-inner left
hinge-inner right
hinge-outer left
hinge-outer right
z-motor-bracket left
z-motor-bracket right
z-top left
z-top right
y-motor
y-idler
y-belt clamp
x-end-motor
x-end-idler
x-carriage
extruder-idler
board mount (x2)
其它
加热床
铝制加热床所需
1 aluminium bed plate (4mm thick)
1块铝材床板(4mm厚)
1个100k欧姆的热敏电阻
60cm of 26 AWG wire (blue)
60cm的26 AWG蓝色线
2 ferule 0,5mm²
2块0.5平方的尺度板
1 peltier element 12708 (40x40mm is enough) - ebay
1块TEC1-12708型半导体冷热片(40x40mm足以)
衬垫手提箱
