File Formats
This page provides a list of the various file types that are used in the reprap software toolchain. You may also want to take a look at Useful Software Packages.
AOI
AOI filenames end with .aoi
AOI files are the native file format for Art of Illusion. AoI was never intended to be used as CAD software but you will find a lot of reprap files in this format because AoI is an open source app and is easy to use. In the long run though this app is probably a dead end for designing parts.
COLLADA
GCODE
GCODE filenames normally end with .gcode
These are ascii files that have a list of G-codes. G-codes are the instructions the arduino firmware reads for moving the stepper motors and extruder head.
IGES
IGES filenames normally end with .igs
This is an older open-format CAD file. It has since been superceded by STEP files as of 1995 or so More detail on IGES files can be found in Wikipedia
PDE
PDE filenames end with .pde
Processing Development Environment files are used by the arduino IDE. Processing is basically just C++ with some extra libraries thrown on top.
PLY
- The PLY format is similar to STL in that it is a wireframe mesh representation of a 3D part
STL
STL filenames end with .stl
STL files are an open file standard and are widely used in Computer Aided Manufacturing (CAM) and rapid prototyping. The STL file format is good for printing out parts because it describes a part's surface geometry. Unfortunately, STL files are terrible for doing Computer Aided Design (CAD). They can be imported into CAD applications but are difficult to change. See the link to the article 'CAD vs CAM' in the discussion section below.
STEP
STEP filenames normally end with .stp
STEP files are basically the gold standard for translating between different CAD applications. People that do CAD for a living use STEP files because is an ISO Standard
Discussions about File Formats
- A community specification for an improvement to STL files.
- A community specification for an open 3D file wrapper.
- ""CAD" files vs CAM files - a designer's plea". ... "STLs are to CAD models as a PDF full of photographs of words is to a text file. You can send them both to a printer just fine, but it's a big hassle to fix a typo." ... "the .scad files contain formulas that document what we in the SolidWorks community call "design intent"." ...
