File:Yegah bolt simulator relA.scad
Revision as of 19:02, 24 February 2013 by Yru (talk | contribs) (milled bolt simulator yegahD tooth :) - milled bolt by michal (yru) liberda mounted on golemC printer)
Yegah_bolt_simulator_relA.scad(file size: 2 KB, MIME type: text/x-c)
Warning: This file type may contain malicious code. By executing it, your system may be compromised.
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeDimensionsUserComment
current19:02, 24 February 2013 (2 KB)Yru (talk | contribs)milled bolt simulator yegahD tooth :) - milled bolt by michal (yru) liberda mounted on golemC printer
  • You cannot overwrite this file.
The following page links to this file:
