File:Universal Block 18 or 21 Requred v1.png
Revision as of 06:01, 3 February 2018 by DGoncz (talk | contribs) (The fit of a printed block like this one could be adjusted to fit in slotted square aluminum tube. The slots actually make up really easily at certain scales with a sheet metal nibbler in gages less than 0.062 inch wall but miilling would suffice and a...)
Size of this preview: 599 × 600 pixels. Other resolutions: 240 × 240 pixels | 639 × 640 pixels.
Original file (639 × 640 pixels, file size: 46 KB, MIME type: image/png)
The fit of a printed block like this one could be adjusted to fit in slotted square aluminum tube. The slots actually make up really easily at certain scales with a sheet metal nibbler in gages less than 0.062 inch wall but miilling would suffice and a Bateson, the intended use, could conceivably mill the slots, Once fitted and on a leadscrew through the hole, the ball end contrains only 2 of 6 DoF on a mating part.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 10:20, 3 February 2018 | 639 × 640 (46 KB) | DGoncz (talk | contribs) | The fit of a printed block like this one could be adjusted to fit in slotted square aluminum tube. The slots actually make up really easily at certain scales with a sheet metal nibbler in gages less than 0.062 inch wall but miilling would suffice | |
06:01, 3 February 2018 | 639 × 640 (451 KB) | DGoncz (talk | contribs) | The fit of a printed block like this one could be adjusted to fit in slotted square aluminum tube. The slots actually make up really easily at certain scales with a sheet metal nibbler in gages less than 0.062 inch wall but miilling would suffice and a... |
- You cannot overwrite this file.
File usage
The following page links to this file:
