File:SpoolHead SheetMetal Pencil.PNG
Revision as of 23:30, 24 February 2010 by Jbayless (talk | contribs) (SpoolHead plan B for feeding the wire uses a mechanical pencil with a push-button advance clutch. This method is being pursued due to difficulties with driving two stepper motors independently. A solenoid actuator drives the pencil, which the wire fee)
Size of this preview: 800 × 452 pixels. Other resolutions: 320 × 181 pixels | 1,607 × 907 pixels.
Original file (1,607 × 907 pixels, file size: 198 KB, MIME type: image/png)
SpoolHead plan B for feeding the wire uses a mechanical pencil with a push-button advance clutch. This method is being pursued due to difficulties with driving two stepper motors independently. A solenoid actuator drives the pencil, which the wire feeds through.
Currently, due to repeated plastic extruder failures, the parts are designed to be cut from aluminum sheet on an OMAX waterjet machining center.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 23:30, 24 February 2010 | 1,607 × 907 (198 KB) | Jbayless (talk | contribs) | SpoolHead plan B for feeding the wire uses a mechanical pencil with a push-button advance clutch. This method is being pursued due to difficulties with driving two stepper motors independently. A solenoid actuator drives the pencil, which the wire fee |
- You cannot overwrite this file.
File usage
There are no pages that link to this file.
