File:SpoolHead SheetMetal.PNG
Revision as of 04:03, 22 February 2010 by Jbayless (talk | contribs) (uploaded a new version of "Image:SpoolHead SheetMetal.PNG": SpoolHead wire feeder, done in sheet metal for rapid fabrication on a waterjet or laser cutter. The wire feeder can support either a NEMA 14 or NEMA 17 motor. Cylinders are Ball bearings, fo)
Size of this preview: 800 × 559 pixels. Other resolutions: 320 × 224 pixels | 1,168 × 816 pixels.
Original file (1,168 × 816 pixels, file size: 156 KB, MIME type: image/png)
SpoolHead wire feeder, done in sheet metal for rapid fabrication on a waterjet or laser cutter. The wire feeder can support either a NEMA 14 or NEMA 17 motor. Cylinders are Ball bearings, for tensioning the wire (top pair) and pinching the wire (bottom pair). Slotted holes allows for adjusting ball bearing positioning. A torsion spring (not shown) applies pinching force to the lower ball bearing.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 04:03, 22 February 2010 | 1,168 × 816 (156 KB) | Jbayless (talk | contribs) | SpoolHead wire feeder, done in sheet metal for rapid fabrication on a waterjet or laser cutter. The wire feeder can support either a NEMA 14 or NEMA 17 motor. Cylinders are Ball bearings, for tensioning the wire (top pair) and pinching the wire (bottom). | |
04:02, 22 February 2010 | 387 × 816 (34 KB) | Jbayless (talk | contribs) | SpoolHead wire feeder, done in sheet metal for rapid fabrication on a waterjet or laser cutter. The wire feeder can support either a NEMA 14 or NEMA 17 motor. Cylinders are Ball bearings, for tensioning the wire (top pair) and pinching the wire (botto |
- You cannot overwrite this file.
File usage
There are no pages that link to this file.
