File:Spindle-hub 1off.stl
Revision as of 00:00, 2 August 2010 by Tbuser (talk | contribs) (uploaded a new version of "File:Spindle-hub 1off.stl": moved bearing inset deeper to make new spool design level easier with the other bearings)
Spindle-hub_1off.stl (file size: 235 KB, MIME type: unknown/unknown)
Warning: This file type may contain malicious code.
By executing it, your system may be compromised.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Dimensions | User | Comment | |
current | 00:00, 2 August 2010 | (235 KB) | Tbuser (talk | contribs) | moved bearing inset deeper to make new spool design level easier with the other bearings |
01:35, 28 July 2010 | (235 KB) | Tbuser (talk | contribs) | ||
01:36, 27 July 2010 | (235 KB) | Tbuser (talk | contribs) | fixed bearing diameter | |
01:00, 27 July 2010 | (232 KB) | Tbuser (talk | contribs) |
- You cannot overwrite this file.
File usage
The following page links to this file:
