File:Spindle-hub 1off.stl
Revision as of 01:00, 27 July 2010 by Tbuser (talk | contribs)
Spindle-hub_1off.stl(file size: 235 KB, MIME type: unknown/unknown)
Warning: This file type may contain malicious code. By executing it, your system may be compromised.
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeDimensionsUserComment
current00:00, 2 August 2010 (235 KB)Tbuser (talk | contribs)moved bearing inset deeper to make new spool design level easier with the other bearings
01:35, 28 July 2010 (235 KB)Tbuser (talk | contribs)
01:36, 27 July 2010 (235 KB)Tbuser (talk | contribs)fixed bearing diameter
01:00, 27 July 2010 (232 KB)Tbuser (talk | contribs)
  • You cannot overwrite this file.
The following page links to this file:
