File:Solid Nylon Transformer HV Insulator.zip
Revision as of 07:16, 21 May 2016 by Rapatan (talk | contribs) (Rapatan uploaded a new version of "File:Solid Nylon Transformer HV Insulator.zip": Switch Mode Power Supply Transformer 1KV and 63KV nylon insulators, Printed in Nylon with a 100% Infill(Solid). Unzip the file and open the .STP in FreeCAD th)
Solid_Nylon_Transformer_HV_Insulator.zip (file size: 21 KB, MIME type: application/zip)
Warning: This file type may contain malicious code.
By executing it, your system may be compromised.
Switch Mode Power Supply Transformer 1KV and 63KV nylon insulators, Printed in Nylon with a 100% Infill(Solid). Unzip the file and open the .STP in FreeCAD then export to .STL for 3D Plastic Printer
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Dimensions | User | Comment | |
current | 07:16, 21 May 2016 | (21 KB) | Rapatan (talk | contribs) | Switch Mode Power Supply Transformer 1KV and 63KV nylon insulators, Printed in Nylon with a 100% Infill(Solid). Unzip the file and open the .STP in FreeCAD then export to .STL for 3D Plastic Printer |
- You cannot overwrite this file.
File usage
There are no pages that link to this file.
