File:Solid Nylon Transformer HV Insulator.zip
Revision as of 07:12, 21 May 2016 by Rapatan (talk | contribs) (Switch Mode Power Supply Transformer 1KV and 63KV nylon insulators, Printed in Nylon with a 100% Infill(Solid). Unzip the file and open the .STP in FreeCAD then export to .STL for 3D Plastic Printer)
Solid_Nylon_Transformer_HV_Insulator.zip(file size: 21 KB, MIME type: application/zip)
Warning: This file type may contain malicious code. By executing it, your system may be compromised.
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeDimensionsUserComment
current07:16, 21 May 2016 (21 KB)Rapatan (talk | contribs)Switch Mode Power Supply Transformer 1KV and 63KV nylon insulators, Printed in Nylon with a 100% Infill(Solid). Unzip the file and open the .STP in FreeCAD then export to .STL for 3D Plastic Printer
  • You cannot overwrite this file.
There are no pages that link to this file.
