Revision as of 00:37, 31 March 2014 by Lukan (talk | contribs)
Original file(1,280 × 720 pixels, file size: 492 KB, MIME type: image/jpeg)
Thanks to IRC user Sparky who helped identify the solution to this particular issue.
Slic3r acceleration of the Z-Axis caused the first layer of 5 mm cubes to squish together. This was caused by the acceleration being too fast in Marlin. In vanilla Marlin code the offending lines are:
Line 390
  1. define DEFAULT_MAX_FEEDRATE {500, 500, 5, 25} // (mm/sec)
Line 391
Line 394
  1. define DEFAULT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves
Line 395
  1. define DEFAULT_RETRACT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for retracts
Known working values are:
Line 390
  1. define DEFAULT_MAX_FEEDRATE {300, 300, 3, 25} // (mm/sec)
Line 391
  1. define DEFAULT_MAX_ACCELERATION {1000,1000,5,10000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot.
Line 394
  1. define DEFAULT_ACCELERATION 500 // X, Y, Z and E max acceleration in mm/s^2 for printing moves
Line 395
  1. define DEFAULT_RETRACT_ACCELERATION 500 // X, Y, Z and E max acceleration in mm/s^2 for retracts
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeThumbnailDimensionsUserComment
current16:32, 20 March 2014Thumbnail for version as of 16:32, 20 March 20141,280 × 720 (492 KB)Lukan (talk | contribs)Larger format of the image.
16:19, 20 March 2014Thumbnail for version as of 16:19, 20 March 2014640 × 360 (32 KB)Lukan (talk | contribs)Thanks to IRC user Sparky who helped identify the solution to this particular issue. Slic3r acceleration of the Z-Axis caused the first layer of 5 mm cubes to squish together. This was caused by the acceleration being too fast in Marlin. In vanilla ...
  • You cannot overwrite this file.
The following page links to this file:
