File:Scanner printable parts.zip
Revision as of 08:39, 28 April 2009 by Letsburn00 (talk | contribs) (The basic printable scanner turntable parts. There are five parts. Each is less than 10x10x10cm (ie within makerbot size) with zero overhang (ie millable). CHECK THEM BEFORE YOU PRINT! The parts look good to me, but I'm not a mechanical engineer and I'm)
Scanner_printable_parts.zip (file size: 25 KB, MIME type: application/zip)
Warning: This file type may contain malicious code.
By executing it, your system may be compromised.
The parts look good to me, but I'm not a mechanical engineer and I'm a little bit worried about the gear system. They may need a re-build, but I think the basic design principal is fine. everything which needs to be fitted is done with a little bit of extra space to prevent any tightness when fitting bolts.
The basic how to put together can be found at http://www.freeasinsteins.com/journal/2009/4/28/printable-parts-for-a-3d-scanner.html
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Dimensions | User | Comment | |
current | 08:39, 28 April 2009 | (25 KB) | Letsburn00 (talk | contribs) | The basic printable scanner turntable parts. There are five parts. Each is less than 10x10x10cm (ie within makerbot size) with zero overhang (ie millable). CHECK THEM BEFORE YOU PRINT! The parts look good to me, but I'm not a mechanical engineer and I'm |
- You cannot overwrite this file.
File usage
There are no pages that link to this file.
