File:SampleEagleDR7mm.zip
Revision as of 02:01, 4 January 2011 by Johnnyr (talk | contribs) (Sample design rule file for Eagle. 7mm traces 7mm clearance except pads & vias restring pads & vias more)
SampleEagleDR7mm.zip(file size: 1,018 bytes, MIME type: application/zip)
Warning: This file type may contain malicious code. By executing it, your system may be compromised.
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeDimensionsUserComment
current02:01, 4 January 2011 (1,018 bytes)Johnnyr (talk | contribs)Sample design rule file for Eagle. 7mm traces 7mm clearance except pads & vias restring pads & vias more
  • You cannot overwrite this file.
The following page links to this file:
