File:Panel burned by inflated silicon pad.jpg
Revision as of 14:18, 11 January 2016 by PRZ (talk | contribs) (During heat chamber tests, due to overheating the silicon pad glued on aluminium sheet (installed vertically along wood panel) inflated, closing the 10mm air gap and started a fire on the wood panel.)
Original file(800 × 736 pixels, file size: 68 KB, MIME type: image/jpeg)
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeThumbnailDimensionsUserComment
current14:18, 11 January 2016Thumbnail for version as of 14:18, 11 January 2016800 × 736 (68 KB)PRZ (talk | contribs)During heat chamber tests, due to overheating the silicon pad glued on aluminium sheet (installed vertically along wood panel) inflated, closing the 10mm air gap and started a fire on the wood panel.
  • You cannot overwrite this file.
The following page links to this file:
