File:PLA SpecificHeat.zip
Revision as of 20:37, 4 February 2011 by Jbayless (talk | contribs) (Specific heat data of PLA. Source: Pyda, M., Bopp, R., Wunderlich, B. 2004. Heat capacity of poly(lactic acid), J. Chem. Compiled and edited by [[user: Jbayless] for use in extruder design calculations. Note: Zip file contains a variety of common data)
PLA_SpecificHeat.zip (file size: 49 KB, MIME type: application/zip)
Warning: This file type may contain malicious code.
By executing it, your system may be compromised.
Note: Zip file contains a variety of common data formats:
- xlsx (original file)
- xls
- ods
- txt (tab-delimited values)
- csv (comma-separated values)
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Dimensions | User | Comment | |
current | 20:37, 4 February 2011 | (49 KB) | Jbayless (talk | contribs) | Specific heat data of PLA. Source: Pyda, M., Bopp, R., Wunderlich, B. 2004. Heat capacity of poly(lactic acid), J. Chem. Compiled and edited by [[user: Jbayless] for use in extruder design calculations. Note: Zip file contains a variety of common data |
- You cannot overwrite this file.
