File:OpenX Carriage Full Set.zip
Revision as of 16:54, 15 February 2011 by Buback (talk | contribs) (uploaded a new version of "File:OpenX Carriage Full Set.zip": added a all in one stl and skp file, if you want to print out all the parts in one go.)
OpenX_Carriage_Full_Set.zip(file size: 224 KB, MIME type: application/zip)
Warning: This file type may contain malicious code. By executing it, your system may be compromised.
stl's and sketchup files
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeDimensionsUserComment
current12:08, 17 February 2011 (224 KB)Buback (talk | contribs)fixed the all in one file: part bottoms weren't all on the same plane.
16:54, 15 February 2011 (235 KB)Buback (talk | contribs)added a all in one stl and skp file, if you want to print out all the parts in one go.
14:05, 10 February 2011 (122 KB)Buback (talk | contribs)slight change to the carriage. A test model snuck in before, with one side only 3mm thick.
15:11, 8 February 2011 (114 KB)Buback (talk | contribs)carriage.stl was broken, fixed in this file
20:27, 7 February 2011 (114 KB)Buback (talk | contribs)stl's and sketchup files
  • You cannot overwrite this file.
The following page links to this file:
