File:OHM OpenY.zip
Revision as of 20:43, 28 February 2013 by Dms5982 (talk | contribs) (uploaded a new version of "File:OHM OpenY.zip": updated version of OpenY_8mm Belt Harness_1off, flipped openY_arm45 to avoid slic3r error)
OHM_OpenY.zip(file size: 57 KB, MIME type: application/zip)
Warning: This file type may contain malicious code. By executing it, your system may be compromised.
STL files needed to construct the Open Y
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeDimensionsUserComment
current20:43, 28 February 2013 (57 KB)Dms5982 (talk | contribs)updated version of OpenY_8mm Belt Harness_1off, flipped openY_arm45 to avoid slic3r error
20:06, 15 January 2013 (56 KB)Jib5181 (talk | contribs)OpenY_45 arm STL updated
21:41, 6 December 2012 (61 KB)Jib5181 (talk | contribs)added bed springs
21:40, 6 December 2012 (50 KB)Jib5181 (talk | contribs)STL files needed to construct the Open Y
  • You cannot overwrite this file.
