File:Little Driver 1 9.jpg
Little Driver 1.9 Heated Bed Power Module - 900 Watt Upgrade
The Little Driver is a premium control board with many features not found in other control boards.
User manuals are available from the Digital Sqrt website. (see below for link)
The Little Driver can be controlled by an existing heated bed output or directly by a microprocessor (3v or 5v logic). All of Digital Sqrt's products are open source and manufactured in the USA.
Little Driver Power Module features:
Full documentation / Not just a single pic, actual documentation (www.digital-sqrt.com/documentation) Upgrade any 3D printer control board Max 900 Watt delivery to any non-inductive load Runs on 12v-30v Drives up to 30Amps (don't be fooled by claim's of 210 or 50-60 amps, go HERE to find out more) Uses existing output as control Alternate control from 3v or 5v logic Optically Isolated (Printer Control Board and Heated bed can have different power supplies) Auxiliary fan connection On board air flow through heat sink Opensource Hardware design NEW with Ver 1.9 50% Smaller than our closest competitor. 30% Smaller than our original design. Unpolarized control lines. Just plug it into your Heated bed output, The +/- no longer matter. You can't wire wrong!
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 06:11, 12 June 2017 | 933 × 742 (632 KB) | AdrianW (talk | contribs) | Little Driver 1.9 Heated Bed Power Module - 900 Watt Upgrade The Little Driver is a premium control board with many features not found in other control boards. User manuals are available from the Digital Sqrt website. (see below for link) The... |
- You cannot overwrite this file.
File usage
The following page links to this file:
