File:Last frame cut display medium.jpg
Revision as of 16:19, 31 August 2012 by Eventorbot (talk | contribs) (After you have finished the frame and have welded the corners together, you will also have to cut a 2.5" x 2.5" square on top of the frame (the corner caps will cover this corner).)
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 16:19, 31 August 2012 | 800 × 534 (61 KB) | Eventorbot (talk | contribs) | After you have finished the frame and have welded the corners together, you will also have to cut a 2.5" x 2.5" square on top of the frame (the corner caps will cover this corner). |
- You cannot overwrite this file.
File usage
The following 2 pages link to this file:
