File:Jbayless 6mm nozzle set.jpeg
Revision as of 00:24, 7 August 2010 by Rocket scientist (talk | contribs) (uploaded a new version of "File:Jbayless 6mm nozzle set.jpeg": smaller)
6mm glass nozzle tips for jbayless to experiment with. 3 nozzles made by standard technique of heating tip until surface tension draws it shut, then grinding off the tip until the desired size orifice is revealed. 1 heated and drawn until much thinner, but still bigger then 0.5mm. 2 practice pieces to test compression fittings with.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 00:24, 7 August 2010 | 800 × 547 (181 KB) | Rocket scientist (talk | contribs) | smaller | |
00:12, 7 August 2010 | 1,435 × 981 (508 KB) | Rocket scientist (talk | contribs) | 6mm glass nozzle tips for jbayless to experiment with. 3 nozzles made by standard technique of heating tip until surface tension draws it shut, then grinding off the tip until the desired size orifice is revealed. 1 heated and drawn until much thinner, bu |
- You cannot overwrite this file.
File usage
There are no pages that link to this file.
