File:Ironing part2.JPG
Revision as of 07:16, 30 June 2013 by RobertKuhlmann (talk | contribs) (Always use paper towels between the layout and the iron to avoid smearing of fine details of the print and to get the most sharpest lines possible. Pressure is good and needed anywhere over the layout. The iron should be as hot as possible. That gives th)
Size of this preview: 800 × 533 pixels. Other resolutions: 320 × 213 pixels | 3,888 × 2,592 pixels.
Original file (3,888 × 2,592 pixels, file size: 2.82 MB, MIME type: image/jpeg)
Pressure is good and needed anywhere over the layout. The iron should be as hot as possible. That gives the best results.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 07:16, 30 June 2013 | 3,888 × 2,592 (2.82 MB) | RobertKuhlmann (talk | contribs) | Always use paper towels between the layout and the iron to avoid smearing of fine details of the print and to get the most sharpest lines possible. Pressure is good and needed anywhere over the layout. The iron should be as hot as possible. That gives th |
- You cannot overwrite this file.
File usage
The following 2 pages link to this file:
