File:IMG 7687.JPG
Revision as of 12:41, 1 November 2010 by Rocket scientist (talk | contribs) (McWire X stage complete, Y stage partial, Z stage backstop only)
Size of this preview: 800 × 600 pixels. Other resolutions: 320 × 240 pixels | 2,272 × 1,704 pixels.
Original file (2,272 × 1,704 pixels, file size: 1,011 KB, MIME type: image/jpeg)
At this step, the X stage is complete. The drive nut has been tapped and threaded onto the lead screw, and manually moved to near the center of motion. The 1/4-20 hex head bolts that secure it to the X stage still need to be counter sunk to leave space for the Y stage lead screw and drive nut. Note the cut in half blue compression springs used to pressure the roller arms firmly against the outer X slide rail. The same technique is visible on the Y stage holding onto the right slide rail.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 10:54, 1 November 2010 | 2,272 × 1,704 (1,011 KB) | Rocket scientist (talk | contribs) |
- You cannot overwrite this file.
File usage
There are no pages that link to this file.
