File:Heatbed top.jpg
Revision as of 01:48, 29 September 2014 by LoH (talk | contribs) (Top view of a nichrome heatbed on an (ab)used circuit board. Note the kapton tape protecting the surface of the board. The scorch marks are from an earlier design that failed. Each heating length is secured by the screws and the loop-end is taped down....)
Size of this preview: 413 × 599 pixels. Other resolutions: 165 × 240 pixels | 1,024 × 1,485 pixels.
Original file (1,024 × 1,485 pixels, file size: 330 KB, MIME type: image/jpeg)
Note the #6-32 screws on both sides of the board, this was done to make the wiring below easier.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 01:48, 29 September 2014 | 1,024 × 1,485 (330 KB) | LoH (talk | contribs) | Top view of a nichrome heatbed on an (ab)used circuit board. Note the kapton tape protecting the surface of the board. The scorch marks are from an earlier design that failed. Each heating length is secured by the screws and the loop-end is taped down.... |
- You cannot overwrite this file.
File usage
The following 2 pages link to this file:
