File:DWG 10-11-12 ROSTOCK MAX LASERFILES BY PARTDADDY SEEMECNC.zip
Revision as of 14:42, 11 October 2012 by Johnoly99 (talk | contribs)
DWG_10-11-12_ROSTOCK_MAX_LASERFILES_BY_PARTDADDY_SEEMECNC.zip(file size: 146 KB, MIME type: application/zip)
Warning: This file type may contain malicious code. By executing it, your system may be compromised.
DWG files for the RostockMAX by SeeMeCNC. Working release. These files are intended to be cut using 1/4" acrylic or similar materials. If you are planning on using any other thickness material, you will have to widen the slots where any tabbed fingers might go in the three round pieces etc...
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeDimensionsUserComment
current14:33, 11 October 2012 (146 KB)Partdaddy (talk | contribs)DWG Laser Only files for the RostockMAX by SeeMeCNC. Working release.
  • You cannot overwrite this file.
The following page links to this file:
